Hid & DRL
Old Dec 20, 2012 | 05:24 AM
vince_fra's Avatar
Hid & DRL
Hello everyone,
I have a question to ask, i try to find a solution to be make my front lights more efficient.
The soluce seems to be the HID conversion kits, but my car does have the DRL, so i wonder how it will work with the HID witch is not able to work at 70% of its power, it's on or off.
Thanks in advance .
The french Mustanger
Old Dec 20, 2012 | 07:06 PM
Zaksgt's Avatar
Originally Posted by vince_fra
Hello everyone,
Thanks in advance .
Take the DRL fuse out.
Old Dec 20, 2012 | 10:20 PM
A Dustman's Avatar
These mustangs do not have a DRL fuse.
The DRLs on these cars are run through pulse width modulation, all that is needed to make an HID kit work without any issues, is a proper relay harness. My car has DRL, and I recently did a bi-xenon fx-r projector retrofit with some after market headlights, I suggest you go this route as well, it may be a bit more expensive, but you will not be blinding people with the horrible glare of a plug and play kit, plus you get amazing light distribution with a sharp cutoff.
Check out the following website for lots of information regarding projector retrofits and other lighting goodness.
www.hidplanet.com
Dustin
Old Dec 21, 2012 | 06:09 AM
vince_fra's Avatar
Thank you i will go & check hoping they deliver in France
Diode Dynamics
Jun 12, 2018 03:26 PM
tang65c
Oct 6, 2015 07:39 PM
VGMStudios
Aug 6, 2015 07:57 AM
