Ford Plenum Cover Rub Marks
Shortly after installing the Ford Plenum Cover, I'm starting to get black rub marks on the top middle of the cover from the hood liner. I tried cleaning it off but I think it's the plenum paint coming off.
Anyone have this problem and does anyone have a fix?
have the same problem and i do not think it is fixable, but then again MWAG makes the fuel rail covers the same color as the factory frod cover so if they sell a touch up paint it would be awesome
This was a prior topic. Some people have had luck using carpet tape between the hood liner & hood. I never got that ambitious, I keep a folded washcloth on top of the cover where the liner contacts. Stays in place & keeps the paint from wearing off.
i had the same problems, but with the fuel rail covers from MWAG. I called them and they do not sell touchup paint.
I tried calling ford to see if they had the touchup paint and they didn't even know what I was talking about
. So I went to a local hobby store and checked out their paints, found one called aluminum and tried it and it matched almost perfectly, if I look close you can see where I touched up but from a distance it looks great. Hope this helps.
can't help you with the paint, but this will stop the problem http://www.granatellimotorsports.com/pdf/manual74.pdf
This fix doesn't really work. Tried it. The 2007 owners are lucky because the hood liner is different than the ones on the 2005-2006 cars. I figure for $49 for the intake cover who cares. When it gets ugly enough I'll just buy a new one.
