"fix-a-flat" spray and tpms?
not sure exactly where to post this, but i got a flat tire today. took my car to the service station and they put that plug into the hole.
anyways, not sure how permanent that repair would be. i was wondering if there was any harm in using those "fix-a-flat" sprays with cars equipped with tpms sensors? i was thinking that the spray would really gunk it all up. that wouldn't affect the function at all, would it?
thanks in advance.
thanks in advance.
I wouldn't use that stuff at all. It makes a mess in side your tire. Take it to a good tire store and have them check the repair and re-do it if necesary. Some tire stores will charge you extra if you've used it cause they have to clean it out first.
plug a cheap used up tire....patch a good tire with lots of tread left on it. Plugs are bad. They work to fix the leak but I wouldn't use one on a good tire. Fix a flat is good if your stranded on the side of the road
As for Fix-a-Flat? If your car doesn't come with it, DON'T USE IT!!! My dad told me it makes a mess inside the tire, and most shops hate it with a passion. A real PITA to clean up.
Use it as a last resort. We charge an extra 10 bucks when we repair a tire with fix a flat.
Also don't plug the tire from the outside. It voids the warranty on the tire. For a reason! Its considered an improper repair and if a tire failure happens because of it, lawsuit city for the "shop" that did it.
I have had tons of tires with "rope" plugs come in still leaking.
A patch, or plug/patch from the inside is the best way. Plug/patch imo.
The patch seals the leak, the plug seals the tire from moisture entering the hole left by the nail into the steel belt package and causing them to rust and separate.
Just another opinion, but I have 18 years in the tire industry.
thanks everybody. i will stay away from the fix-a-flat spray. they used that "rope" plug, and it seems fine, but i will see if someone can fix it with a patch.
appreciate all the input.
all those Ford GT, Shelby and Bullitt owners who no longer get spare tires?If you look in my trunk you'll see something similar to this where the spare tire should be:
If that is Fix A Flat in that yes I am saying that. That stuff is horrible. I have seen many times what it has done to the inside of wheels including my own whihc is why i would never use it again.
