Drilling?
Old May 3, 2007 | 06:14 PM
WuTimeUT's Avatar
Drilling?
Well my Roush Spoiler that I used tape on is a little looser than I would like. Soooo I think I'm going to drill but I'm REALLY nervous about drilling into my baby! Any suggestions? I don't own a drill so will probably be borrowing one or renting one. I need help!
Old May 3, 2007 | 07:02 PM
Sharky's Avatar
1.Be aware of what you're drilling into.... and whats behind it.
2.Anytime i've had to drill into my car, I mask the entire area to prevent ut oh's.
3. Measure, then measure again and when you're absolutely sure where you're going to drill measure once more.
4. A little primer/ touch-up around newly drilled holes will prevent the rusties. And i don't care how water tight a part is... it will get wet.
5. 3M makes some kick butt auto tapes for stubborn parts, the proper prep and this tape is almost as good as drilling.
6. A blanket under the area you are drilling into is a good idea to catch shavings.
all i can think of for now
Old May 3, 2007 | 07:42 PM
itsmetoo's Avatar
I drilled for my Roush spoiler. Most important...check and double check your template before drilling. One mistake I made was mounting the trunk lid piece before drilling holes for the side pieces. I would suggest drilling all the holes before mounting. The template that comes with the Roush spoiler is pretty accurate.
Like Darral stated primer/ touch-up paing on the holes us a must.
One thing I did was to fill in the holes with silicone after placing the spoiler on but before putting the nuts on. This will prevent any water that may get underneath to leak into the trunk.
Old May 3, 2007 | 10:37 PM
JonCo's Avatar
Pictures of your car? Im interested in seeing how the wing and louvers fit. Im on the fence with those two mods.
Old May 3, 2007 | 11:14 PM
itsmetoo's Avatar
Here is the only picture I have at the moment. I will post some better shots in the next couple days.
Old May 4, 2007 | 10:36 PM
Cobrakev's Avatar
Just remember to use a drill punch to mark the hole before you start drilling. That way the bit will not move around on you.
Old May 5, 2007 | 12:25 AM
rmays06's Avatar
Very brave to drill into a car!!! Good luck oh and for grins and giggles measure once more!
Joeywhat
Sep 6, 2015 08:09 AM
GLOCKer
Aug 13, 2015 09:55 AM
RRRoamer
05-09 Interior and Audio Mods
69
Feb 21, 2006 03:58 PM
BigWorm2005GT
05-09 Exterior Modifications
14
May 30, 2005 05:48 PM
