Chin Spoiler/Spliter Inquiry
I have always thought that the CDC classic chin spoiler looked the best IMO, but after seeing a few in person I am having second thoughts about buying one. I am concerned about damaging it on a parking stop or a speed bump. (especially after I lower the car an inch) Does anyone know if theres a spoiler out there that keeps approximately the same plane and does not hang down much?
1 Post
I bought and modified the oem GT500 splitter, I've learned to not pull all the way up when I pull in to a parking space, and if for some reason I do and it's damaged I can replace it for under $70.00.
Bill, was the modification a pita? I've read that you need to cut a couple sections out so that it will sit flush. Did you use the exsisting mounting points?
I have had the CDC classic for about 3 years. I had had it repainted twice and did it one time myself. Two of the times is was my fault (******* attack) and once I hit a pipe sticking out of asphalt at night. I have thought about removing it but IMO for an otherwise stock body, it looks "just right".
I like my Astra Hammond (Wilpack) spoiler. I had a CDC classic spoiler on an '06 I used to own and I had to do some touch up a couple of time before I sold the car. Clearance was a problem and my car was stock height. No problems with the Astra spoiler so far. It has better ground clearance and already comes in a textured black finish. It is a good compromise between a splitter and spoiler. I got mine on sale from Ninosports.
9/16/15 06:44 PM
MUSTANGfan2010
05-09 Exterior Modifications
8/15/15 06:42 PM
