Best tail light sequencers?
Old 2/20/07, 05:44 AM
Rapture's Avatar
Originally Posted by YardSpecial
Well I went CDC for price and stock harness replacement.
Was like $146 shipped...........with NO CORE.
Install was like 15 minutes tops.
Love the look..........
I went CDC also
Old 2/20/07, 10:15 AM
RRRoamer's Avatar
Thanks for the feedback! So it looks like I need to dig deeper into the Web Electronics kit and the CDC kit and probably should give some look to the Meter4it kit as well (even though it does require splicing...).
Your participation is appreciated!
Old 2/20/07, 10:19 AM
05RedGT's Avatar
CDC kit was simple to install.
Old 2/20/07, 10:32 AM
+5 on Webelectric!
Simple to install, check it out here.
Old 2/20/07, 11:59 AM
sodaman's Avatar
web electric all the way, plug n play, the only true plug n play I know of. I have owned the cdc, and it is not plug n play, almost, but not! web electric sequencers rule. good luck
Old 2/20/07, 12:17 PM
karrnutt's Avatar
I swear by Webelectric"s products and their warranty all the way! They are the best!!!!!
Old 2/20/07, 02:55 PM
LEO_06GT's Avatar
How can you say CDC's are not fully plug and play. All you do is remove the factory harness and put the CDC harness in it's place using the factory bulbs. There's not cutting/splicing of anything. How can web electrics be any easier???
Here's the instructions to prove it.
CDC install
http://www.classicdesignconcepts.com...t_kit%20TS.pdf
Webelectric install
http://www.webelectricproducts.com/products.htm
Old 2/20/07, 03:00 PM
Leo, I'm guessing you have the CDC D-Sticks?
Old 2/20/07, 03:14 PM
LEO_06GT's Avatar
Yup. I don't really care if people buy webelectric/CDC it's just I don't like bad info being put out. In reality both kit's are dam near identical and do the exact same thing. They also cost the same so it's just matter of which company you like more CDC or webelectric.
Old 2/20/07, 03:50 PM
freyke's Avatar
I have had the CDC Dynamite Sticks for over a year and a half, no problems, real easy to install.
Old 2/20/07, 04:32 PM
RRRoamer's Avatar
Leo,
Actually, it looks like your statement is only true for 2006-2007 MY vehicles. The instructions for 2005 (which I have) show the original moding the pin into the factory harness method.
I should send them an email and ask them why the full harness isn't available for the 2005. According to their web site, there was a change to the bulb harness in late 2005 (slightly different style connector, but the wiring is potted in place, so they can't insert the new wire pin). The part that irritates me is that the full harness costs exactly the same as the 2005 add on part.
At this point, I definitely am leaning towards the Web Electronics version.
Old 2/20/07, 04:42 PM
Alloy 07 RN's Avatar
+6 on Webelectric!
I just love watching peoples faces in amazement from my rear view mirror!
Old 2/20/07, 05:11 PM
tom281's Avatar
I guess I don't understand what all the fuss is about plug and play systems. I mean really, installing the hard-wired kits is not hard. Anyway, I don't have a preference I just think that although the P&P is very easy, we shouldn't scare away anyone from doing a hard-wired kit based solely on the thought that it's a tough install.
This is the system that I'll be buying from SHR- basically one wire hookup and then plug and play. http://www.silverhorseracing.com/web...ategory_id=255
Old 2/20/07, 05:54 PM
LEO_06GT's Avatar
Originally Posted by RRRoamer
Leo,
Touche! So with that said if you have a 2005 go with web electric and if you have 2006+ go with CDC.
89Trooper's Avatar
Meter4It - hands down. The chase is so much better than the regular sequentials. And it's really not hard to install at all.
The splicing is worth it! Do you want easy... or awesome?
And like others have mentioned, you can have regular brake lights, sequential, or chase - all with a simple change of a jumper.
Old 2/20/07, 06:10 PM
sodaman's Avatar
well unless they changed it, cdc you had to run a wire thru a grommet, and plug it into the light bulb housing, and to run the wire they want you to cut a slice in the wiring grommet for the light bulb housing. At least when I had them you had to do this and add the 3rd bulb I think. Web electrics came fully ready to plug up, no running extra wire, and slicing gromets and what not. So like I said I have owned the cdc dynamite sequentials and you did have to modify, I am not saying it was hard but you did. Web electric, un plug the harness, and take out the bulbs, plug in the new harness and bulbs, and your done. So like I said unless they have changed theres, you are wrong they are not the same. If they did change them my apologies.
Old 2/20/07, 06:16 PM
GottaHaveIt's Avatar
I be liking the Web then because you can just unplug it all and put back the way it was should say a warrenty become an issue.
Old 2/20/07, 06:18 PM
05fordgt's Avatar
I love my Webelectics kit. No problems, and it gets lots of stares at the stop lights.
Old 2/20/07, 06:26 PM
Dougxox's Avatar
I have those on my car, what one wire ???, just plug and play. There made by GT Concepts. What I like best is the brake lights go in a fast sequential also.
Oh I have an 07, on the 05 and part of the 06 they are different. I still love them
Old 2/20/07, 06:48 PM
  #40
tom281's Avatar
Yep, on the '05s and early '06s there is one wire to hook up, then p&p.
Quick Reply: Best tail light sequencers?
