Backspacing on stock GT bullits?
Old Jun 21, 2006 | 04:35 PM
atomic_il's Avatar
Does anyone know the specs on these as far as backspacing and how far apart the lugnuts are and what not?
I really just need to know if i can fit a set of these on the rear for drag tires. http://www.cragar.com/WheelsDetail.asp?id=397
Old Jun 21, 2006 | 05:00 PM
Stangers's Avatar
45mm BS and 4 1/2 bolt pattern on the stock 05+ Bullitts.
Hope this helps.
Old Jun 21, 2006 | 08:21 PM
StangNut's Avatar
Hope this helps.
The offset is +45mm. Not the backspacing. Also the bolt pattern is 5 x 4 1/2".
The back spacing is about 6 1/2". I'm still looking for the exact number though.
My wheels are 18x9 and have a +36mm offset with 6.41" of backspacing if that helps at all. I think the stock wheels on the previous Mustangs were +24mm with 5.85" of bs. The wheels you are looking at are probably made for a car that has numbers closer to those.
EDIT: After doing some quick digging, I think the '05 bs was 6.77". I know the offset was +45mm.
09-gt/cs
Oct 15, 2015 10:03 AM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Ray11
Sep 25, 2015 12:43 PM
samjluck
Sep 17, 2015 10:24 PM
