Anyone Running 275-50/17 Rear Tires?
Old Oct 19, 2006 | 09:58 PM
GRAYPNY's Avatar
I have the Nitto NT450 tires and I am happy with them but I am thinking of going with the 275-50/17 rears for alittle more width. Anyone running this combo? Pictures are always good!
Old Oct 21, 2006 | 06:53 AM
05 Retro's Avatar
I'm running them in the rear with my stock Perilli's up front but their not Nittos their Falkens.
Old Oct 21, 2006 | 06:56 AM
05 Retro's Avatar
I'm running them on the rear with my stock Perilli's up front but their not Nitto's their Falkens.
Attached Thumbnails Anyone Running 275-50/17 Rear Tires?-05-mustang-088.jpg   Anyone Running 275-50/17 Rear Tires?-05-mustang-052.jpg   Anyone Running 275-50/17 Rear Tires?-05-mustang-064.jpg
Old Oct 21, 2006 | 07:08 AM
SC67Stang's Avatar
Runnin' 275/40ZR18 Goodyear Eagle F-1 in the rear on mine.
Old Oct 21, 2006 | 01:23 PM
GRAYPNY's Avatar
Thanks for the pictures. They do stick outside of lower fender quite abit. Any problems with rock chips, etc?
Old Oct 21, 2006 | 01:26 PM
05 Retro's Avatar
Not with mine but I only drive her in the good weather.
Old Oct 21, 2006 | 01:29 PM
GRAYPNY's Avatar
I always thought that is was a bad thing to run different thread patterns on front and rear, but I guess if you aren't running them in wet weather it probably doesn't matter.
Old Oct 22, 2006 | 12:54 AM
Gearhead's Avatar
235mm, 55%, 17" rubber has this diameter:
(23.5cm/2.54 cm/in) * 55% * 2 + 17" = 27.2"
255mm, 50%, 17" rubber has this diameter:
(25.5cm/2.54 cm/in) * 50% * 2 + 17" = 27.0"
@ 60 MPH Indicated, you are traveling at 60 MPH actual
275mm, 50%, 17" rubber has this diameter:
(27.5cm/2.54 cm/in) * 50% * 2 + 17" = 27.8"
@ 60 MPH Indicated, you really are traveling at 61 MPH
275mm, 45%, 17" rubber has this diameter:
(27.5cm/2.54 cm/in) * 45% * 2 + 17" = 26.7"
@ 60 MPH Indicated, you really are traveling at 59 MPH
Old Oct 22, 2006 | 12:27 PM
AFBLUE's Avatar
Dethroned Nascar Guru
Dumb question. Does the speedometer and odometer go off the front or rear tires?
Old Oct 22, 2006 | 01:27 PM
SlamMan02's Avatar
I would think it was the rears because think about when you are on a Dyno, The speedo moves while the front wheels do not.
Also when you are doin a burnout/brakestand the speedo will move while you are spinning your tires even if you are in one spot.
Old Oct 22, 2006 | 03:21 PM
AFBLUE's Avatar
Thanks. You're right. I should have thought about it.
Old Oct 22, 2006 | 05:49 PM
SlamMan02's Avatar
No biggie just tryin to help out
Ecostang
Nov 3, 2022 08:50 PM
MRGTX
Aug 15, 2015 07:45 PM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
