Anyone with larger than 275's on a 10" rim??
Old Feb 21, 2008 | 03:24 PM
mustangspeeder's Avatar
I currently have 275/35/20 on my 10" rims and am looking to go wider and a little taller. BFG makes KDW's that are 295/40/20 that I want, but when I called Discount Tire the guy there said that they would rub without making modifications to the car in the wheel well.
Is anyone running larger than 275 with out problems or has anyone HAD problems with a certain width/height??
Old Feb 21, 2008 | 03:53 PM
69_gt500's Avatar
I have Nitto 295/45 om my 10" rims with no problems, I also got the complete setup at discount tire.com
Attached Thumbnails Anyone with larger than 275's on a 10" rim??-recentpics9-1-07006.jpg   Anyone with larger than 275's on a 10" rim??-recentpics9-1-07001.jpg
Old Feb 21, 2008 | 06:03 PM
tom281's Avatar
Heck I run 275s on my 9" wheels...... you could go 285 or 295 easy.
Old Feb 21, 2008 | 06:27 PM
nycstang37's Avatar
i run 285 bfg kdw's, just remember every manufacturers tires are different. the kdw's are easily wider then some other brands, een if the same size so as far as fitting on a rim you could go 285-295 even seen 305 but watch out for clearance on the car with some brands
Old Feb 21, 2008 | 06:51 PM
Got Oatz's Avatar
295/40/20 on 10 inch rims no problem....
Attached Thumbnails Anyone with larger than 275's on a 10" rim??-toyos-007-large-.jpg
Old Feb 21, 2008 | 07:33 PM
WuTimeUT's Avatar
295/40/20 you'll have no problems
Old Feb 21, 2008 | 07:56 PM
2kanchoo's Avatar
I have 305/45/18 nitto 555R's and don't have any problems. I also have my car lowered 1.5". You gotta have a stiff suspension setup to get away with what I'm running tho. 28.8" overall height and a 1.5 drop doesn't leave much clearance.
Old Feb 21, 2008 | 07:58 PM
STANG_IT's Avatar
295/35/19 on a 10" rim here and no problems. Mind you, an adjustable panhard bar helped.
Old Feb 22, 2008 | 05:13 AM
05YellowGT's Avatar
My wheels are either 9.0" or 9.5" wide , I don't remember exactly , and I run 285/35/19 on the rear with no problem ...
Old Feb 22, 2008 | 08:21 AM
Hatchman's Avatar
+1, tires from Discount Tire as well.
Old Feb 22, 2008 | 08:39 AM
Awesome, thanks a lot guys! Time to go blow $700
Old Feb 22, 2008 | 02:46 PM
SpeedRacer's Avatar
Let us know how it works out. I am thinking about going with that size also on my 20's. I have the same springs also.
Old Feb 22, 2008 | 03:59 PM
DarkFireGT's Avatar
I have 295/45/18 555's ready to go on some 18x10's. KoolDawg is running that exact setup. It looks awesome.
Old Feb 22, 2008 | 04:57 PM
rrobello's Avatar
TMS West Coast Correspondent
Im running 18x10s in the rear with 295x40s and no problem at all, no where close.
Old Feb 22, 2008 | 08:27 PM
kooldawg6's Avatar
cozyp828
Dec 13, 2017 05:53 PM
trackpack13gt
Jul 25, 2017 05:29 PM
samjluck
Oct 26, 2015 05:17 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
Evil_Capri
Sep 25, 2015 12:56 PM
