285 30 20
Old Jul 18, 2011 | 09:46 PM
yugoboss's Avatar
285 30 20
Any pics of some members rides with 285 30 20 rear tires. Guess I'm just having trouble finding some.
Old Jul 19, 2011 | 07:34 AM
musshoss's Avatar
285-30-20 is a very common tire size. you shouldnt have any problems finding them. check tirerack, onlinetires, discount tire
Old Jul 19, 2011 | 03:33 PM
yugoboss's Avatar
No I want to see members that have them
On there car.
Old Jul 19, 2011 | 03:40 PM
5pointoh's Avatar
I believe there is a wheel and tire thread on here somewhere. I contemplated about this size for my back but decided to stick with 275/35/20 as 285/30/20 is going to be shorter than the stock height and if you are planning on running 255/35/20 in the front.....the tire in the front is going to be taller by a little bit.
I prefer to go with the more aggressive slightly raked look.....I have a +24mm offset with my Shelby Razors.....so 275 or 285 does not make a huge difference in looks from the back view. The +24mm offset really enhances the look of the tire (i.e. makes it look even bigger) in the back.
Old Jul 19, 2011 | 04:11 PM
SpeedRacer's Avatar
^^^ what he said.
Old Jul 19, 2011 | 04:14 PM
2010MustangGT's Avatar
Google image, "285/30/20 mustang" done.
Old Jul 23, 2011 | 08:28 AM
MrLatte's Avatar
Hopefully you can see the photos in this thread. The tires on the back are 285/30-20s with 255/35-20s on the front:
http://www.svtcobraclub.com/forums/s...93&postcount=7
Personally, I think 295/30-20s will look a little better (although Toyo Proxes 4s are one of the few tires in this size) since the sidewall is about the same height as the front 255/35-20s.
Old Jul 23, 2011 | 09:34 AM
Shotokan1509's Avatar
That sounds a bit short at 26.8", I run 27.6" (275/35/20) tall lowered on FRPP springs. I actually want slightly wider & taller in the rear next time I need tires.
Old Jul 25, 2011 | 10:11 PM
yugoboss's Avatar
Thanks for all the info, I decided to go with
The 275 35 20 for the rear.
MRGTX
2007-2009 Shelby GT500
Jan 2, 2024 04:30 PM
Ed M.
05-09 Exterior Modifications
48
Dec 6, 2019 01:24 AM
ETNOATS
Aug 16, 2011 10:18 PM
Jaden
Nov 8, 2009 06:02 PM
GTracer
Jun 2, 2006 04:27 AM
