2005 Antenna Removal
Old Jun 1, 2005 | 10:15 PM
fleasome's Avatar
Was just curious if anyone that has removed and replaced their antenna could give me a step by step "Antenna for Idiot's" guide. Got a new one coming and will replace mine in next day or two.
Old Jun 2, 2005 | 05:33 AM
Donna's Avatar
Queen Of Nascar
Its really easy. Just unscrew one and screw the new one on.
Old Jun 2, 2005 | 06:45 AM
PonyGirl's Avatar
I wrapped a towel around the base of the antenna and used a rubber set of pliers to help unscrew it. ( this is done so you dont scratch the base black paint off while trying to unscrew it)......It is very hard to start it, then it just unscrews and you replace the new one.
Old Jun 2, 2005 | 06:56 AM
Hatchman's Avatar
I used some electric tape to wrap around the base, and I think it was a 10mm wrench. Just loosen it up a little then unscrew it. I put a dab of Loctite on the new one's threads, and screwed it in, wrapped electric tape around the base and tightened it up with the wrench again. Easy, 5 minutes, tops.
Old Jun 2, 2005 | 10:17 AM
mustangshadow's Avatar
has anyone noticed by changing out your antenna worse radio reception? Just curious because I have thought about changing mine as well
Old Jun 2, 2005 | 11:04 AM
biznazion's Avatar
I picked up a 14" shorty antenna off ebay and the radio reception is unchanged. I don't use the radio that much since I can hold so many mp3's in the shaker - but the look of the stock antenna was buggin me.
Old Jun 2, 2005 | 12:09 PM
My Blue Heaven's Avatar
I've got an 8" antenna on mine and my mp3's come in fine.
Chris
Old Jun 2, 2005 | 12:33 PM
Adrenal's Avatar
I put a 13" shorty on mine and can't tell any difference in reception.
Old Jun 2, 2005 | 12:45 PM
CA Stang's Avatar
I put an 8" antenna, from mustangtuning.com, on mine and haven't had any negative change in my reception.
Old Jun 2, 2005 | 11:53 PM
Sonic V8's Avatar
Go to the hardware store and buy a small piece of thick silicone hose.. The same kind that is used to drain water from your home A/C unit. Put it around the base of the antenna and unscrew it with pliers..
