11 inch wide rims
Old May 12, 2005 | 03:00 PM
dallasw77's Avatar
I have seen some companies offer 11inch wide rims for the 05, but has anyone tried to go that wide?? And if there is a right offset will they fit without sticking out from the fender? Thanks in advance.
Old May 12, 2005 | 03:12 PM
ZwerRacing's Avatar
I dont know but I am also intrested in finding out how wide you can go? I wd even get custrom wheels made if you could go wider
Old May 12, 2005 | 03:14 PM
ManEHawke's Avatar
sticking our of the fender won't be your only concern, there could be clearance issues from inside the wheel well housing.
Old May 12, 2005 | 05:55 PM
j-stang's Avatar
I have 18x9.5" all around - let me tell you I wouldn't feel comfortable going much larger in the front. I kow Roush is running 10" but that has to be close. My tire is pretty close to the strut. I can barely get my finger in between.
Old May 12, 2005 | 07:56 PM
wild stray's Avatar
I was measured for the wheels I have on order and the widest I could go was 10.25 inches for the back.
Paul
Old May 12, 2005 | 08:18 PM
Lalo's Avatar
I'm people, and I like.
One things I wish Ford would have done for the Stang was make it possible to have a deep dish wheel without it sticking all the way out like it does. You cant even have sn95 bullitts without having them stick out of the fender.
Old May 12, 2005 | 09:29 PM
friedmaster's Avatar
It is because the axles are wider than before, and the ends of each axle are closer to the outside of the car. Im not sure, but I think this does help with the suspension geometry by allowing the springs to be closer to the outside.
Old May 12, 2005 | 10:01 PM
ManEHawke's Avatar
They can always add a wider body to accomodate, and flares that stick out about an inch farther (nothing too crazy)
This will alow a nice deep lip while keeping the axles the same length. Maybe for a future model?
Old May 13, 2005 | 06:09 AM
Grubby's Avatar
18x9.5" .... I've been seeing a lot of that. I assume you could do that with a drop of 1.5 or 2 right?
Old May 13, 2005 | 06:58 AM
j-stang's Avatar
Yeah- Brian you can still drop it. My wheels are still snug inside the fender.
Old May 16, 2005 | 10:36 PM
BLoG's Avatar
Has anyone looked at the 18x10 fikse wheels like on the Grand AM Cup mustangs? Any guesses as to what the equivalent steet tire size would be?
Old May 17, 2005 | 01:51 AM
wild stray's Avatar
Without any special mods, I think 285's are about as big as you're going to get in there.
Paul
Old May 17, 2005 | 07:49 AM
adrenalin's Avatar
I've got 18x10 with 285's on the rear. I have 1/4" space from the inside of the rim to the inside of the wheelwell. The outside of the rim is even with the wheelwell. I think you can get away with 295's but that would be it, however if you drop your car like I did it would definately rub.
Old May 17, 2005 | 07:53 AM
dallasw77's Avatar
John,
Are your rims +45mm offset?
Thanks!
Old May 17, 2005 | 10:45 AM
adrenalin's Avatar
The 18x10's in the rear are a 45mm offset
Old May 17, 2005 | 10:29 PM
wardog's Avatar
H&R claimed to have shoehorned an 11" wide rim on the back with 305's.
http://www.hrsprings.com/site/index.html
Old May 18, 2005 | 06:35 AM
adrenalin's Avatar
Man that is one ugly stang. Too ricey for me.
cozyp828
Dec 13, 2017 05:53 PM
trackpack13gt
Jul 25, 2017 05:29 PM
samjluck
Oct 26, 2015 05:17 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
