11 inch wide rims
I have seen some companies offer 11inch wide rims for the 05, but has anyone tried to go that wide?? And if there is a right offset will they fit without sticking out from the fender? Thanks in advance.
I have 18x9.5" all around - let me tell you I wouldn't feel comfortable going much larger in the front. I kow Roush is running 10" but that has to be close. My tire is pretty close to the strut. I can barely get my finger in between.
One things I wish Ford would have done for the Stang was make it possible to have a deep dish wheel without it sticking all the way out like it does. You cant even have sn95 bullitts without having them stick out of the fender.
They can always add a wider body to accomodate, and flares that stick out about an inch farther (nothing too crazy)
This will alow a nice deep lip while keeping the axles the same length. Maybe for a future model?
I've got 18x10 with 285's on the rear. I have 1/4" space from the inside of the rim to the inside of the wheelwell. The outside of the rim is even with the wheelwell. I think you can get away with 295's but that would be it, however if you drop your car like I did it would definately rub.
H&R claimed to have shoehorned an 11" wide rim on the back with 305's.
http://www.hrsprings.com/site/index.html
