Stock wheels and new tires
Old Feb 1, 2005 | 08:49 PM
jsheehan's Avatar
I have two questions. First, how wide are te stock rims on the V6? Second, how wide of tires can I put on these rims? The tires on the new V6 are too narrow, and I'd like to replace them with some wider rubber. However, I like the style of the V6 rims, and I don't want to add any extra weight that I have to get turning. I can tell by looking at the rims that there is still some room between the edge of the rim and the stock tires, but I don't know absolutely how wide I can go.
Old Feb 1, 2005 | 09:02 PM
islandmustang's Avatar
245/50/16...thats the widest im going...some tires give up to 10in wide.....
Old Feb 1, 2005 | 09:04 PM
jsheehan's Avatar
You think 245s will fit on these rims? If so, that would be perfect for me. I was figuing maybe 235s at the most.
Old Feb 2, 2005 | 07:16 AM
Rik's Avatar
Rik
Originally posted by jsheehan+February 1, 2005, 10:07 PM--><div class='quotetop'>QUOTE(jsheehan @ February 1, 2005, 10:07 PM)</div><div class='quotemain'><!--QuoteBegin-islandmustang@February 1, 2005, 10:05 PM
[/b][/quote]
The rims are 16" by 7". 245/55's willl fit, although that's right at the edge of what's safe for 7" rims (245/50's are NOT recommended.)
I plan to go with 235/60's. If the car ever gets here.... :bang:
Go here to see how they'd look, and to compare sizes:
http://www.1010tires.com/tiresizecalculator.asp
Old Feb 2, 2005 | 11:15 AM
slowjoe24's Avatar
Thanks....................that's a great tool for tires!!!
Old Feb 2, 2005 | 11:31 AM
shave35's Avatar
I just put 255/55/16 on my stock rims for he rear only, and they look great on the back of the car. Plus with this size my speedo is not affected.
Old Feb 2, 2005 | 01:16 PM
Rik's Avatar
Rik
Two-FIFTY-fives? You're a braver man than I am.
I'm sure they look awesome, but be careful, man...
Old Feb 3, 2005 | 11:19 PM
well i had 245/50/16s on my camaro v6..and they were fine...but overall, the camaro and a mustang 2 separate cars...
Old Feb 4, 2005 | 07:13 AM
Rik's Avatar
Rik
Doesn't the V6 Camaro have 16 x 8 wheels, though?
Old Feb 6, 2005 | 07:50 PM
DanS.02GT's Avatar
According to Tirerack's specs, a 245/50/16 is approved for a 7" to 8.5" wide wheel. The slight difference in diameter would cause about a 5% speedo error, though.
Old Feb 8, 2005 | 08:03 PM
slowjoe24's Avatar
[quote=DanS.02GT,February 6, 2005, 8:53 PM]
Any photo's?????? I would love to see these tires on the factory wheels!!!
Old Feb 9, 2005 | 07:34 AM
Rik's Avatar
Rik
Yes, I know. That's why I said 7" rims are right at the edge of what's considered safe. I'm sure they'll be fine, I'm just a bigger chicken than you are, which is why I'll stick with the 235's. They are approved for 6.5-8.5 rims.
By the way, it's only a 1.5% speedo error, not 5%. You won't even notice.
However, there's also another consideration for me: Tirerack has only ONE brand of tire in 245/55 size, and they cost $174 apiece. I plan to get the Kumhos in a 235/60 size, which are much more reasonable at $60. I had those on my V6 Firebird some years ago, and they worked well for me.
Slowjoe: you are right, the 245's will look massive on 16" rims. You can see what a difference they'll make in the illustration at the bottom of that tire-measurement site I posted above.
Old Feb 9, 2005 | 02:22 PM
bison's Avatar
I'm with Rik, I wouldn't go any wider than 235mm on 7" rims. Adding wider tires doesn't do much good if you don't have rims wide enough to support the sidewall. IMO 235s on a 7" rim is already pushing it.
I plan to go with 235/60-16s, probably Traction T/As. These are "real" 6-rib Traction T/As, not the OEM 5-rib design that Ford uses on the V6. The tread is completely different - the 5-rib design looks like it was optimized for a quiet ride. I have 6-rib Traction T/As on my Honda, and they are a fantastic tire. A lot of other people seem to think so too:
http://www.tirerack.com/tires/tires.jsp?ti...artnum=36HR6TTA
BTW, 235/60-16 is almost identical in diameter to the stock 215/65-16s.
Old Feb 9, 2005 | 08:30 PM
slowjoe24's Avatar
I understand what everyone is saying but I had a 1997 Lincoln Mark VIII "LSC" with the same size wheels 16" x 7". It came factory with 225/60/16 tires, however, I was able to put 245/50/16 on it with NO Problems!! It changed the whole look of the car.....Very aggresive looking. I know that our V6 wheel is also a 16" x 7", but it comes from the factory with a whimpy 215/65/16 tires and it takes away from the good looks of the factory rims. I just wish someone had photos of a 245/50/16 tire on the 2005 Mustang V6 Wheels. Bottom line is that I believe that it will work and that it will look Awesome!!! Can't wait to see someone try it. My $0.02
If anyone cares......here is a photo of my Old Lincoln:
dohc97
17
Aug 14, 2015 07:12 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
trackpack13gt
Jul 23, 2015 11:13 PM
whowasthat
Jul 19, 2015 01:49 PM
