I have two questions. First, how wide are te stock rims on the V6? Second, how wide of tires can I put on these rims? The tires on the new V6 are too narrow, and I'd like to replace them with some wider rubber. However, I like the style of the V6 rims, and I don't want to add any extra weight that I have to get turning. I can tell by looking at the rims that there is still some room between the edge of the rim and the stock tires, but I don't know absolutely how wide I can go.
245/50/16...thats the widest im going...some tires give up to 10in wide.....
Originally posted by islandmustang@February 1, 2005, 10:05 PM 245/50/16...thats the widest im going...some tires give up to 10in wide..... |
Originally posted by jsheehan+February 1, 2005, 10:07 PM--><div class='quotetop'>QUOTE(jsheehan @ February 1, 2005, 10:07 PM)</div><div class='quotemain'><!--QuoteBegin-islandmustang@February 1, 2005, 10:05 PM 245/50/16...thats the widest im going...some tires give up to 10in wide..... [/b][/quote] The rims are 16" by 7". 245/55's willl fit, although that's right at the edge of what's safe for 7" rims (245/50's are NOT recommended.) I plan to go with 235/60's. If the car ever gets here.... :bang: Go here to see how they'd look, and to compare sizes: http://www.1010tires.com/tiresizecalculator.asp |
Thanks....................that's a great tool for tires!!!
I just put 255/55/16 on my stock rims for he rear only, and they look great on the back of the car. Plus with this size my speedo is not affected. :nice:
Two-FIFTY-fives? You're a braver man than I am.
I'm sure they look awesome, but be careful, man... |
well i had 245/50/16s on my camaro v6..and they were fine...but overall, the camaro and a mustang 2 separate cars...
Originally posted by islandmustang@February 4, 2005, 12:22 AM well i had 245/50/16s on my camaro v6..and they were fine...but overall, the camaro and a mustang 2 separate cars... |
According to Tirerack's specs, a 245/50/16 is approved for a 7" to 8.5" wide wheel. The slight difference in diameter would cause about a 5% speedo error, though.
[quote=DanS.02GT,February 6, 2005, 8:53 PM]
According to Tirerack's specs, a 245/50/16 is approved for a 7" to 8.5" wide wheel. Any photo's?????? I would love to see these tires on the factory wheels!!! :dunno: |
Originally posted by DanS.02GT@February 6, 2005, 8:53 PM According to Tirerack's specs, a 245/50/16 is approved for a 7" to 8.5" wide wheel. The slight difference in diameter would cause about a 5% speedo error, though. By the way, it's only a 1.5% speedo error, not 5%. You won't even notice. However, there's also another consideration for me: Tirerack has only ONE brand of tire in 245/55 size, and they cost $174 apiece. I plan to get the Kumhos in a 235/60 size, which are much more reasonable at $60. I had those on my V6 Firebird some years ago, and they worked well for me. Slowjoe: you are right, the 245's will look massive on 16" rims. You can see what a difference they'll make in the illustration at the bottom of that tire-measurement site I posted above. |
Originally posted by jsheehan@February 1, 2005, 9:52 PM I have two questions. First, how wide are te stock rims on the V6? Second, how wide of tires can I put on these rims? The tires on the new V6 are too narrow, and I'd like to replace them with some wider rubber. However, I like the style of the V6 rims, and I don't want to add any extra weight that I have to get turning. I can tell by looking at the rims that there is still some room between the edge of the rim and the stock tires, but I don't know absolutely how wide I can go. I plan to go with 235/60-16s, probably Traction T/As. These are "real" 6-rib Traction T/As, not the OEM 5-rib design that Ford uses on the V6. The tread is completely different - the 5-rib design looks like it was optimized for a quiet ride. I have 6-rib Traction T/As on my Honda, and they are a fantastic tire. A lot of other people seem to think so too: http://www.tirerack.com/tires/tires.jsp?ti...artnum=36HR6TTA BTW, 235/60-16 is almost identical in diameter to the stock 215/65-16s. |
I understand what everyone is saying but I had a 1997 Lincoln Mark VIII "LSC" with the same size wheels 16" x 7". It came factory with 225/60/16 tires, however, I was able to put 245/50/16 on it with NO Problems!! It changed the whole look of the car.....Very aggresive looking. I know that our V6 wheel is also a 16" x 7", but it comes from the factory with a whimpy 215/65/16 tires and it takes away from the good looks of the factory rims. I just wish someone had photos of a 245/50/16 tire on the 2005 Mustang V6 Wheels. Bottom line is that I believe that it will work and that it will look Awesome!!! Can't wait to see someone try it. My $0.02
If anyone cares......here is a photo of my Old Lincoln: |
