Steeda Cold air intake question
"2005 Mustang Cold Air Intake Kit (05 V6)
Gain horsepower and torque with this straightforward upgrade. Lifetime filter can be cleaned and re-oiled, but the big news here is that Steeda streamlined the airflow in the 05 Mustang to the point that a computer re-flash isn't just an option, it's required! Check out the SCT Xcalibrator - the perfect tool for the job!
The kit is supplied with a stainless steel air box with built-in velocity stack and CNC billet aluminum mass air meter. It mounts in the factory location with the supplied rubber trim to seal it against the hood & fender to keep the hot air out. Steeda's tests showed inlet temps a mere 10 degrees above ambient temperature. The Steeda Lifetime Filter can easily be cleaned and re-oiled, making maintenance a snap. All hardware required for installation is included in the kit.
Steeda found between 16 -20 more rear wheel horsepower with this kit.
Availability: Usually ships the next business day.
16138$259.95"
Does this mean i cant reach a 20 horse power gain with out the computer reflash?......Sorry about the question but im fairly new to all this
16138$259.95"
EDIT: My bad, you are correct, you cannot reach that w/o the flash. The car will likely not run correctly without the reflash. Mess up the A/F
Originally posted by Johnny Mustang@December 1, 2005, 10:56 PM
Did you guys get +20Hp with the steeda?
and by the way how is the X-cal used?
Ecoboost
7/25/15 06:32 PM
