Steeda Cold air intake question
Old Dec 1, 2005 | 02:41 PM
Johnny Mustang's Avatar
"2005 Mustang Cold Air Intake Kit (05 V6)
Gain horsepower and torque with this straightforward upgrade. Lifetime filter can be cleaned and re-oiled, but the big news here is that Steeda streamlined the airflow in the 05 Mustang to the point that a computer re-flash isn't just an option, it's required! Check out the SCT Xcalibrator - the perfect tool for the job!
The kit is supplied with a stainless steel air box with built-in velocity stack and CNC billet aluminum mass air meter. It mounts in the factory location with the supplied rubber trim to seal it against the hood & fender to keep the hot air out. Steeda's tests showed inlet temps a mere 10 degrees above ambient temperature. The Steeda Lifetime Filter can easily be cleaned and re-oiled, making maintenance a snap. All hardware required for installation is included in the kit.
Steeda found between 16 -20 more rear wheel horsepower with this kit.
Availability: Usually ships the next business day.
16138$259.95"
Does this mean i cant reach a 20 horse power gain with out the computer reflash?......Sorry about the question but im fairly new to all this
Old Dec 1, 2005 | 07:03 PM
Martimus's Avatar
Actually quite the opposite. The Steeda intake absolutely REQUIRES a custom tune. Without it you'll likely have a check engine light (CEL) soon after installing it.
Old Dec 1, 2005 | 07:34 PM
korinwoodo's Avatar
Did you not read your post?
EDIT: My bad, you are correct, you cannot reach that w/o the flash. The car will likely not run correctly without the reflash. Mess up the A/F
Old Dec 1, 2005 | 07:42 PM
Thomas S's Avatar
I have the Steeda, it's great. You need the tune. You want the tune, trust me. The tune is more important than the CAI, IMO. I recommend BamaChips for the SCT-2.
Old Dec 1, 2005 | 07:46 PM
scotts05custom's Avatar
I also have the Steeda intake and the X-Cal2.
I got mine in a package deal from BrenSpeed.
It amazes me.
Old Dec 1, 2005 | 07:53 PM
Did you guys get +20Hp with the steeda?
and by the way how is the X-cal used?
Old Dec 1, 2005 | 07:57 PM
Thomas S's Avatar
I haven't had my car dynoed. You plug it in below and to the left of the steering column and follow the directions. Very simple.
Old Dec 1, 2005 | 10:25 PM
Like Jimp said, the X-Cal 2 is very easy to use, and I don't know about the 20 HP, but I do know you will be able to spin the tires VERY easily with the intake and a tune...
jonser
Ecoboost
Aug 30, 2015 11:47 AM
jlaval05
Aug 27, 2015 10:08 AM
GT/CS Guy
Aug 13, 2015 07:54 PM
Ecoboost
Jul 25, 2015 06:32 PM
