New brakes.
Old Nov 3, 2011 | 11:49 AM
em305's Avatar
New brakes.
I got 2005 mustang v6 and my brakes seem to be ****. I already tired changing the pads and it did nothing. Any of you guys know good places and or prices where a can get a full brake kit.?
Old Nov 3, 2011 | 12:06 PM
AirForcePonycar's Avatar
Have you checked americanmuscle.com? They should have some good brake parts for ya.
Old Nov 3, 2011 | 02:33 PM
em305's Avatar
I checked them befor on other parts and they were kinda pricey but I'll see how much there brake kits are thks.
Old Nov 3, 2011 | 08:09 PM
jabdesign010's Avatar
Just upgrade to the gt front brakes bigger calipers bigger bite you can but the kit from Ford and I think American muscle too
Old Nov 5, 2011 | 10:23 AM
Womprat's Avatar
The stock brakes on the six are weak.
Start by adding better pads and rotors, I have used Powerslot rotors and Hawk HPS pads for years and the improvement is tremendous. Also dump the stock rubber lines and put in some stainless ones, this will firm it up under hard braking and they are more resilient to road debris.
Top it off with a full flush and add some higher quality fluid, DOT 4 for example.
This will be well under a grand if you do the work yourself and the improvement will be like night and day, I have autocrossed on this setup for years and never had any doubt the brakes would not get the job done when needed.
Old Nov 5, 2011 | 10:55 AM
em305's Avatar
Thks for the info I'll think I Migth give that a try .... How much do you think it would cost me for.?
Old Dec 31, 2011 | 06:21 PM
amustangrocks's Avatar
so what did you end up doing? do you have 17" wheels? if you do, the gt frt upgrade is a good deal, 2 new oem gt rotors and the brackets for the caliper.
if you can find just the brackets somewhere ( junk yard ect) you can get 4 drillede and slotted rotors with the gt size up frt and ceramic pads for just over $200. i couldnt find just the brackets so i got the gt upgrade kit from cjpony, then bought the drilled slotted rotors and pads. i did the V6 set of the same on our 06 which still has 16" wheels. the V6 set is the same price as the gt set. cant beat that price.
http://cgi.ebay.com/ebaymotors/Drill...item3369de2bc5
Old Jan 1, 2012 | 10:27 AM
cpotts13's Avatar
This is probably your best bet for a daily driver, no real need for bigger brakes unless you track the car..
Old Jan 2, 2012 | 10:50 AM
silversky545's Avatar
Check this out... Hope it helps... Stage 3 motorsports
Old Jan 2, 2012 | 11:54 AM
Womprat's Avatar
That looks like a good deal there!
Check out rotorpros.net as well they work with forums and have some really good prices.
Christmas had some pretty deep savings on most of the part sites like AM and CJ's/latemodelresto. Check around!
1001yos
Sep 8, 2015 10:05 PM
BassMoBill
Mar 13, 2007 08:33 PM
Lokius
05-09 Exterior Modifications
30
Jan 18, 2007 05:19 PM
TMSBrad
Project Source Horse
23
Sep 12, 2006 05:03 PM
