engine noise
Old 6/6/11 | 10:09 AM
Ditmer's Avatar
engine noise
My stang is making a harsh whistle from 3k rpm to 3.5k. I can't tell what it is, the engine light doesn't come on n it doesn't show its running lean anywhere, so does anyone have any clue what it could be? Its an automatic v6 if that helps, and yes I know this probably isn't the best section for this but I couldn't think of anywhere else better suited.
Old 6/6/11 | 12:08 PM
Gtpony325's Avatar
Are you 100% posotive that its the engine making the noise? I only ask because my mom has an 05 v6 and it had a nasty whistle. Turned out thatshe had a bad window seal on the passenger side and the wind was blowing under it. It sounded like a small dog howling inside of her car.
Old 6/6/11 | 10:41 PM
Ditmer's Avatar
Yep. Definitly something under the hood.
Old 6/7/11 | 06:23 AM
Gtpony325's Avatar
Ok. Well do you have any mods or is it still stock? The first place i would check is the belt and pulleys
Old 6/7/11 | 07:57 AM
Ditmer's Avatar
Still stock (hopefully that'll change eventually but id like to get rid of this noise first) I will check that as that would make sense since its just a certain rpm range, and I have tried to find stuff on google n it suggests checking the intake manifold. I was just hoping that someone on here woulda had this problem.
Old 6/7/11 | 08:22 AM
Gtpony325's Avatar
I suppose if the intake manifold was cracked it would make a whistling noise. That does sound like a possibility. Hopefully you find it sooner that later.
Road_Runner
9/2/24 04:46 PM
Uofmrampage
8/2/22 02:55 PM
JonathonK
Which is Better
11/17/17 12:02 PM
Mr. V
12/24/16 02:57 PM
Quick Reply: engine noise
