engine noise
engine noise
My stang is making a harsh whistle from 3k rpm to 3.5k. I can't tell what it is, the engine light doesn't come on n it doesn't show its running lean anywhere, so does anyone have any clue what it could be? Its an automatic v6 if that helps, and yes I know this probably isn't the best section for this but I couldn't think of anywhere else better suited.
Are you 100% posotive that its the engine making the noise? I only ask because my mom has an 05 v6 and it had a nasty whistle. Turned out thatshe had a bad window seal on the passenger side and the wind was blowing under it. It sounded like a small dog howling inside of her car.
Still stock (hopefully that'll change eventually but id like to get rid of this noise first) I will check that as that would make sense since its just a certain rpm range, and I have tried to find stuff on google n it suggests checking the intake manifold. I was just hoping that someone on here woulda had this problem.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
