Clutch Pedal Problem!!?!?!
Old Jul 11, 2012 | 10:16 PM
Stallion408's Avatar
What's up TMS fam! Ive got an 07 v6 and I've been having some clutch pedal issues. When I'm at a red light and I have my foot on the clutch, the clutch pedal gets stuck in. It also happens slowly but progressively when I shift gears. I have to put my foot under the peadal and pull it out. Anyone know what might be the problem???
Old Jul 30, 2012 | 01:01 PM
Doug@C&L's Avatar
Sounds like you may be leaking fluid in your clutch system, check your reservoir and check for leaks in the system. If you dont know much about it take it somewhere, it shouldn't be much just to check it out.
Thanks, Doug
Old Aug 2, 2012 | 11:19 AM
Torch_Vert's Avatar
There's also a return spring on the pedal up at the pivot point under the dash. I'd take a look at that to be sure it's not broken or out of place. You can see it to the left of the circled 8 and 9 in this diagram:
Old Aug 3, 2012 | 03:34 PM
Thanks for the info guys much appreciated. Now just got to go check it out.
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
