Cheap, Easy Mods
Old Aug 20, 2013 | 10:41 PM
Selmar's Avatar
Cheap, Easy Mods
Hey guys and ladies, I got my 4.0 05 and I'm wondering if there is any easier stuff that won't cost to much to Help my All around Output?
Old Aug 21, 2013 | 06:16 AM
CiniZter's Avatar
cheapest mod i did was plastic dip n spray tinting....
Old Aug 21, 2013 | 06:47 PM
amustangrocks's Avatar
you can pick up a used or takeoff set of gt mufflers and swap out that v6 muffler. thats the first thing i did while i was waiting on my h pipe setup to come to go dual. might pick up 5-10 hp just by doing that. it wont be loud, but it will sound just a little better and flows better
Old Aug 21, 2013 | 10:32 PM
Selmar's Avatar
Sweet thanks man, I might go straight to double, with an H-pipe, any idea on how much increased HP I will get, or any other stuff that would be affected?
Old Aug 22, 2013 | 06:41 AM
I have two sets of gt mufflers and an x pipe for sale in the for sale section. Mike stated you might pick up 5 to 10 hp. I also have a stock gt h pipe if your interested in that instead of the x pipe.
Old Aug 22, 2013 | 07:38 AM
its hard to get a h pipe as no one makes them. ive got the jba and have been real happy. you could have a muff shop fab the gt h to work on the v6. the h will sound a little better than the x, but either will help.
on the 05 something else you should do is a bi-pass to the coolant hoses going to the throttle body. they omitted them after 05. they are not needed and it makes removing the tb real easy (4 bolts-2 connectors) which at the same time you should remove and clean. get a can of tb cleaner at the auto parts. the inside should look like clean alum with no black. thats gonna help all around performance. heres a post i did on another forum back on 08. it shows a pic of where the hoses are. i just used the longer hose and made a loop, but you could just block it off any way you want.
http://www.allfordmustangs.com/forum...ss-review.html
another thing sorta cheap that i wish i would have done alot sooner is install a oil catch can between the PCV valve and the plenum. it keeps alot of oil from going into the intake, which coats everything. i got one off ebay for $30. ive got some install posts on this if you ever need it
Attached Thumbnails Cheap, Easy Mods-cana.jpg   Cheap, Easy Mods-can7.jpg   Cheap, Easy Mods-canc.jpg
Old Aug 22, 2013 | 05:30 PM
scramblerider5's Avatar
I just went with tint and a tuner
Old Aug 23, 2013 | 06:02 PM
another great mod is some takeoff or used gt frt and rear sway bars. HUGE improvement in handling,the gt struts are nice too. rear shocks are the same as the v6
http://www.newtakeoff.com/mustang-16.aspx
Old Oct 5, 2013 | 05:33 AM
MasterMan9720's Avatar
The Best mods I can recommend that are somewhat cheap with a big difference is a CAI, prob any kind of open air filter will do..A tuner is an amazing device that will do wonders...for a chunk of change. A strut tower brace will make a noticeable difference in handling...Other than that, use full synthetic oil for oil changes, and remove any excess weight from the car...Good Luck!
Old Oct 7, 2013 | 08:44 AM
CiniZter's Avatar
^ this.. i m hearing this quite often now... people looking to reduce weight than adding HP.
Old Oct 12, 2013 | 09:51 PM
it is huge, if your gonna race your car, but the tradeoff there is you have a stripped down car. everything ive added has also added weight, over size brakes, big wide tires, all the parts, but i like my car alot more with the added weight. i have made some lighter moves though, the alum driveshaft is pretty big, and chrome moly rear control arms, alum panhard bar. all in all, ive found it hard to do
Old Jan 23, 2014 | 02:17 PM
nycwipeout's Avatar
CAI's
Are there any CAI's for a 06 where you don't need to tune and won't wreck the engine?
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Bryanh24
Oct 14, 2015 08:43 AM
