Best Looking CAI for the V6 ? ? ? ?
Thanks guys. I wanted to show Socal.2fast what the C&L looks like polished.
First, those are old pictures. I don't have the C&L installed anymore as Denny noticed.
I have changed things from time to time as my mood changed.
Q - "How long did it take them? I would think after having it polished to have
a clear coat put on it so it dose not Dull?"
A - It took the shop about three days to do the job. It did not get clear coated but I shined it so often it never got a chance to dull. Not to say you couldn't or shouldn't have it clear coated.
Q - "How much boost are you running?"
A - 10 psi
Q - "what other dress up parts do you have on there they look good."
A - In those pics I have the UPR strut tower cap set, MWAG plenum cover (personally customized), and I painted the fuse box cover & alternator cover with the closest dupli-color I could find. These are old pics and since then I have changed a lot. MWAG body color painted plenum cover, strut towers caps, fuse box cover, radiator cover & extensions. MGW radiator cap, oil fill cap & dipstick handle
Q - "How do you think the polish is holding up? Clear Coat?"
A - I've had the C&L off since last March. It is packed away. While it was on it lasted through the Midwest winter with no problems. I just kept it shined all the time.
A - 10 psi
Here's the newest shots I have. The engine shots are from March & the car show shot is from July.
I did not sell the C&L but before you ask I'm not selling it. I want to keep it in case I ever have to remove the Procharger. Sorry.
I don't have the body color radiator cover & extensions on because I had to cut them to fit the Procharger in and I didn't want to cut the expensive ones until I knew everything was running good & the Procharger was staying on the car. But you can see the black extensions.
![](http://i58.photobucket.com/albums/g252/garyb900/2008_0311Image0148.jpg)
![](http://i58.photobucket.com/albums/g252/garyb900/2008_0311Image0147.jpg)
![](http://i58.photobucket.com/albums/g252/garyb900/2008_0311Image0146.jpg)
![](http://i58.photobucket.com/albums/g252/garyb900/2008_07130076.jpg)
Hey Gary,
Those are some nice numbers! I was going to take my ride to the dyno today, but with all the snow in NYC I pushed it back to the third of next month.
Keep up the good work!
Thanks Denny. Looks like you've got a good setup too.
I know what you mean about the snow. I need to get out and do some datalogging on a different tune I have but not in this weather. Good luck on the dyno. Hope you get some good New Years numbers!
