Whats the Noraml Max Fuel and Oil Pressures?
Old Feb 12, 2008 | 12:52 PM
07Foose's Avatar
I will be installing some gauges soon and would like to know the Maximum Normal Fuel and Oil pressure levels, so I don't get gauges that don't go high enough. Just making sure as I don't think normal fuel and oil pressures would exceed 80-100 psi. (**** I'm post ho'n today, Gov't employee has to do something all day ) Thanks...
Old Feb 12, 2008 | 04:31 PM
70MACH1OWNER's Avatar
Well stock fuel pressure is 40 PSI and cold you may run 60 PSI oil pressure. But I see you have a Roushcharger installed so your fuel pressure may be bumped to like 50 psi when you are at WOT.
Scott
Old Feb 12, 2008 | 05:51 PM
sook's Avatar
I get an 80 psi spike on oil pressure at start up. a 0-100 psi gauge should be fine.
Old Feb 12, 2008 | 08:16 PM
07Foose's Avatar
Thx all...
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Sep 8, 2015 10:45 AM
