What Would Be Considered Normal Noise
Old Jun 15, 2008 | 10:29 PM
Jon_Purdy's Avatar
Hello everyone. A couple weeks ago I had Tokico Blues and H&R Sport Springs installed and I am quite happy with them except over mild bumps (i.e. parking lot speed bumps, etc.). Not in terms of ride quality just the noise I hear when the front wheels first strike the bumps. I seem to only hear it when going fairly slow. Is this considered normal or could there be something wrong?
Jon
Old Jun 15, 2008 | 10:36 PM
Did you replace or reuse the plastic factory strut mount bushing on the front struts?
These are a item that has been known to fail and they are also a one time use item that should be replaced onced removed during the strut or spring change. I used the J&M caster/camber plates to avoid this and I can reuse them as much as I want. You might at least replace with OEM bushing as suggested by Ford.
Old Jun 15, 2008 | 10:57 PM
Jon_Purdy's Avatar
I failed to mention that I did indeed also install MRT adjustable camber plates. What bushing are you referring to?
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
ricky1728
Feb 11, 2016 07:25 PM
09-gt/cs
Oct 15, 2015 10:03 AM
southern stang
Sep 26, 2015 04:19 PM
