what do I need to avoid wheel hop?
Old Feb 9, 2007 | 04:13 PM
  #41
freebass55's Avatar
I have never experienced any wheel hop, but I am still running on stock tires. Does that make a difference. Will I see this when I get the DRs?
Old Feb 9, 2007 | 04:21 PM
  #42
tom281's Avatar
Originally Posted by thump_rrr
You know you've experienced wheelhop when you've seen the dash bouncing back and forth a few inches.
Yep, that's it..... the dash dances around more than this dude:
Oh I know I don't want the dreaded hop. I've had cars that would hop so bad that it would shake your teeth loose. But remember... I am starting at idle and building up to max rpm. I am not starting at 5K like you manual guys.
Scott
I don't know Scott..... maybe this spring we can get together and compare!
Old Feb 9, 2007 | 04:22 PM
  #43
tom281's Avatar
I had the hops on the stock 17" Pirellis.......
Old Feb 9, 2007 | 05:01 PM
  #44
theedge67's Avatar
Mine hops the worst when I don't dump the clutch. When I just engage the clutch at a lower rpm, but still at full throttle, when the rpm's get to about 3000, the tires break loose and start hopping like crazy.
Old Sep 24, 2007 | 05:01 PM
  #45
1550GT's Avatar
I don't notice any wheel hop either but I haven't dumped the clutch @ 5000rpm either. I have a manual trans, with 18 inch wheels and I launch @ 2-3000 rpm. My question is would I benefit from replacing the UCA and the LCA or would I be wasting my money. I do not plan on lowering the car and do not go to the track but I am an aggressive driver at times.
Here is a list of suspension mods I was thinking of upgrading over stock. Should I do them all or are some just a waste in my situation.
Nonadjustable UCA, LCA, Panhard bar and brace, and a larger rear sway bar.
My only performance mods are a CAI, underdrive pulleys, and a 93 octane tune. That will be it.
As a side note--when I hammer it into second gear the rear of the car drifts to the left all the time. Why is that?
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
