Ways of measuring air/fuel?
Old Jan 5, 2007 | 11:46 AM
Cavero's Avatar
I did a seach on this and didn't find anything really helpful or newer than 2005. I put in a Granatelli intake and instead of seeing the slight increase in fuel economy usually associated with CAIs I'm actually seeing a decrease of about 1.5mpg around town and on the highway.
So I know about the autometer guages, but was hoping to keep the interior stock. But just out of curiosity, how well do they work and how do they hook up? I know they come with wideband O2 sensors now, but are there any other inputs?
I've also heard about scan tools that go into the OBD-II port that can tell you engine parameters. Anyone use these? Any models that are better than others? $$$? Would Granatelli's jumper harness that conditions the signal from the MAF throw off the readings?
Are there any other options? Thanks in advance
Old Jan 5, 2007 | 12:02 PM
06GTwJUICE's Avatar
you have to have a bung welded onto the exhaust somewhere.. my thinking is to turn off one of hte rear o2's and use that one for a wideband o2 sensor if the threads are the same.
Get a wideband from AEM or autometer and mount the gauge in the glove box, then you have it hidden but can look at it if you want.
As for port scanners... they are all pretty much the same until you get into the xcal or predator tuners..
I don't know about the harness from GMS but my guess is that it just changes the signal going to the computer to adjust for the intake... if you take readings at a point after the harness it should read similar to as if it was never plugged in at all.
Old Jan 5, 2007 | 12:09 PM
tom281's Avatar
A good quality gauge and sensor will do the trick. You will have to have a bung installed on your exhaust- it must go before any cats and/or mufflers. The bung will allow you to insert an oxygen sensor that will work in conjunction with the gauge.
Tom
Old Jan 6, 2007 | 04:02 PM
Cavero's Avatar
hmmm....glovebox is a good idea.
I'm assuming a bung is just a tab that just makes the steel thicker so it can be drilled and threaded?
How many O2 sensors are there? 2 upstream and 2 downstream or just 1 of each?
Old Jan 6, 2007 | 05:12 PM
tom281's Avatar
A bung is a threaded insert that is welded into the pipe. The same thing as what the factory oxygen sensors screw into, if that's easier to picture.
There are 3 sensors; one on the drivers side and two on the passenger side. If you keep the factory midpipe, it will have to be removed and the bung installed way up high, infront of one of the cats; then reinstalled.
Old Jan 6, 2007 | 05:35 PM
Cavero's Avatar
What are the locations of the 3 relative to the cats?
Old Jan 6, 2007 | 05:38 PM
tom281's Avatar
I don't recall on the factory midpipe; its been a year since I had mine on. I can look tomorrow if you want; I have it put up in the attic area of my garage.
Old Jan 6, 2007 | 06:22 PM
Cavero's Avatar
No, that's alright. I can look under my car sometime this week.
I unfortunately can't weld if I decide to put a bung in, so any idea on cost to have it done?
Anyone know the price on the average scanner?
Old Jan 6, 2007 | 06:50 PM
tom281's Avatar
I paid like $45 to have one installed on my factory pipe last year. You can get a kit and gauge here: http://rpmoutlet.com/aemgauge.htm
Old Jan 6, 2007 | 07:13 PM
MyFastGT's Avatar
There are 4 02 sensors. 2 pre cat and 2 post cat.
Old Jan 6, 2007 | 07:16 PM
tom281's Avatar
What? There were four on my '03 and '05 but only 3 on my '06. I doubt yours is different than mine........
I'm referring to the midpipe; is there one on the factory manifolds?
Old Jan 6, 2007 | 07:19 PM
65sohc's Avatar
Hey Cavero,
How do you like those Sylvania bulbs? Any actual improvement over stock?
Old Jan 6, 2007 | 09:23 PM
RedDragon777's Avatar
ok there is one with a green connector above the cat on the passanger side then there is one with a blue connector under the cat on the passanger and drivers side and there is only 3
Old Jan 6, 2007 | 09:25 PM
here is a link with better pics
http://forums.bradbarnett.net/showpo...85&postcount=1
Old Jan 6, 2007 | 09:38 PM
MyFastGT's Avatar
Yes, there is one the driver's side manifold. It is hard to see without digging.
Old Jan 6, 2007 | 09:40 PM
tom281's Avatar
That explains it......... thanks!
Old Jan 7, 2007 | 07:08 AM
70MACH1OWNER's Avatar
Hmmmm... I also thought there is only a total of 3 O2 sensors. 2 on passenger side and 1 on drivers side. I just removed my cats yesterday and got a real good look at both exhaust manifolds ( Thinking Longtubes) and I did not see any O2 sensor on the driver exhaust header. If it's there it is well hid. Mine car is an 05.
Scott
Old Jan 7, 2007 | 12:15 PM
Enfynet's Avatar
I thought the EGR valve was on the driver side manifold?
Old Jan 7, 2007 | 05:18 PM
Cavero's Avatar
Hmm...that's not bad at all. I might consider that then.
Originally Posted by 65sohc
Hey Cavero,
There's a noticeable difference with the headlight bulbs and a huge difference with the foglight bulbs. It was only $65 with all 4 bulbs altogether too.
________________________________
I'll have to take a look under my car this week sometime, but its sounding like there will be 4 sensors, which makes perfect sense. after all, why would the computer only monitor one bank of cylinders? At only $45, I might just have the bung installed and not deal with unplugging O2 sensors already in use.
Old Jan 7, 2007 | 06:04 PM
the GT's do not have EGR's only the V6 and GT500
kponypower
Jun 17, 2020 07:17 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
