Upper Control Arm Users
QUESTION FOR UCA USERS:
For those who have the BMR upper control arm, when removing the gas tank, did you or did you not have the 13mm bolts that held the gas tank straps??
If you have the 13MM bolts, do you have the old gas tank with the (TSB) problem or the new gas tank installed??
I have the new gas tank on mine, when me and "cheese302" went to drop the gas tank to put the UCA on, they were not held on by 13MM bolts, they were held on by TORX BOLTS. Just wanted to see if people with the new gas tanks were replaced with these bolts instead of 13MM bolts.
If not, my dealer messed up big time..... :scratch:
