Update on 1/8 times with 3.31 gear
Old Apr 30, 2005 | 10:54 AM
My Blue Heaven's Avatar
Best time with the 4.10 was 9.04, as I recall weather was in the 50's.
Last night weather in the 50's and dropping, my very first run with the 91 Diablo tune tweaked a/f as it was too lean.
60' 2.145
330 5.923
1/8 9.032 @ 79.55
I believe I was getting a bit more HP out of the tune and the air helped for sure.
Sticky tires and or the exhaust mods/MMR intake I'm doing this week "should" put me into the 8's easily.
towards the end of the night I added one degree of global spark and banged out 3 hotlapped runs of 9.1x at 80mph. Wasn't great off the line, 2.2x 60 times but once it hooked the pull in 2nd and 3rd was great.
My opinion for my circumstances and situation (how's that for heading off the "assinine" replies...) the 4.10 was a waste of money.
8's here I come!
Old Apr 30, 2005 | 11:01 AM
SixtySix's Avatar
Well you know Chris, some people who really know what there talking about kinda agree with you. I think it's turning out to be more of a "feel" mod, than one that helps your strip times.
I've seen people pulling good times either way
Are you starting to get your tunes straightened out? I know you were having a heck of time getting anything out of your tunes.
Old Apr 30, 2005 | 11:45 AM
swingle007's Avatar
Mine made 8.7's with my 4.10's, although I think the 3.73 is still probably the best all around gear for street/strip.....What were your 4.10 times before? Your upcoming mods should get ya smiling for sure!!
John
Old Apr 30, 2005 | 11:51 AM
elvism's Avatar
my best is 8.715 ......stock rear
Old Apr 30, 2005 | 01:33 PM
Kluski's Avatar
I know you drove and auto, but I am going to a 1/8 mile race with a stick, and am wondering, do you make it to third gear?. Or do you stay in 2nd?
Why I am asking is like the 1/4 mile. If I rememebr right, it is on the border of shifting to fourth.
Old Apr 30, 2005 | 01:51 PM
Sonic05's Avatar
Trap speed is 80mph, so yes on third gear right? I usually shift to third at around 60, I'm not sure how much is left in that gear though.
Old Apr 30, 2005 | 02:08 PM
Kluski's Avatar
Thanks that helps, I think 2nd gear and 60 mph is pretty close to the limiter.
Old Apr 30, 2005 | 07:21 PM
I had it back at the Dyno shop Thursday, drove down with a friend who had an 05 with a stick. He got the C&L with the Diablo and was getting his a/f tweaked. He made about 15 I believe, maybe 20, can't recall, and since he made gains we thought "what the heck" lets try it on mine. Well, I made about 15 too. This was with the C&L tune that was out at the time for Diablo. So, I was pretty sure that I was going to be buying me a C&L after that!
We swapped them back and I loaded the r18 diablo 91 tune back into my car and dyno'ed it again with a 3rd gear pull to get around the TC flashing. Well, guess what. Put down 252 in 3rd gear. I figured from deciphering the 4th gear run that I was putting down 255 stock. Went back and looked at an earlier run in 3rd and it was at 235. Soooooo. Somewhere I picked up around 17 horse. I was also really lean with just the stock tune. Still have the factory airbox and it's lean. We rich it up via the tool expecting to lose HP. Nope. Same numbers.
What happened? I have no idea. Short of flashing the unit back to an earlier tune to see if I lose HP I can only assume (yeah, I know) that for whatever reason the early tunes weren't working for me and now they do.
I don't think I'm going to get big gains from the MMR but it looks cool, and with the C&L on I could hear the throttle body SNAPPING open when I nailed it. Never hear that with the stock air box. We'll see.
I'll still try to get a tune from Alternative Auto when the xcal2 comes out due to his work with the auto. I think I'd be well into the 8's/13's if the tranny was tuned as well.
Chris
Old Apr 30, 2005 | 07:26 PM
John
John, your avatar pic is extremely distracting.
Please reply more
My best was 9.04 with lousy 60 times. Typical was 9.1x to 9.3s. That's stock except for tune and the gear.
Best I could do in the 1/4 was 14.06, but that was with suspect tunes. Everything else was stock except the gear.
Chris
Old Apr 30, 2005 | 07:27 PM
When I hit your times I'll be smiling
I'm not going U/D pulleys though so don't know if I can.
chris
Old Apr 30, 2005 | 07:29 PM
3rd gear all the way for the 1/8, got plenty left in it.
In the 1/4 it shifts a little before the line, and with the rev limit up you can just get by in 3rd but I don't know if it helps or not. Haven't done enough tests yet.
chris
Old Apr 30, 2005 | 09:58 PM
stkdidy's Avatar
not arguin with the results that the poster got from going back to stock...but...
if gears are just a feel mod, then explain how they and a pred 91 tune got me a 13.26 @ 106.6
im not a very good driver either, only thing i can do well is powershift
i am and always will be a believer in the power of the gear
Old Apr 30, 2005 | 10:03 PM
SixtySix's Avatar
Don't do a dyno run in third gear. It's WRONG. You need to have a 1:1 ratio to get accurate numbers. You're torque converter shouldn't flash if you ease it up in 4th with the overdrive off.
But you saw your gains, so that's good too. Just know that your 255 is really 270-275.
See Blazing Saddles new run in fourth. He got the numbers he expected, and then some
Old May 1, 2005 | 06:58 PM
Cool, I WAG'd mine at about 270 with the gains I saw in 3rd. I had a small bit of wheel hop ONCE at the 1/8th track with the 4.10.
Friday afternoon I'm planning on installing the x-pipe, mmr intake and the new r21 Predator tune. I'll do a 4th run after we get it as good as it gets and hopefully will still make it to the track that night.
Chris
Old May 2, 2005 | 06:02 AM
JST4FN's Avatar
Originally posted by stkdidy+April 30, 2005, 11:01 PM--><div class='quotetop'>QUOTE(stkdidy @ April 30, 2005, 11:01 PM)</div><div class='quotemain'><!--QuoteBegin-SixtySix@April 30, 2005, 10:04 AM
[/b][/quote]
You are comparing a standard to a auto and they are totally different animals in this car.
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
ssjbuu
Aug 28, 2015 08:55 AM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
chadh92
Jul 29, 2015 06:56 AM
