Transmission swap?automatic to manual
Would anybody recommend me to change the automatic trans for a manual one? Does the manual on a 08 S197 have common issue like problems with shifting and stuff like this?
Is there any 6speed that is offered to work with the Mustang gt 2008?
I would check out this new Tremec 6-speed as it eliminates all the shifting issues associated with the externally mounted shifters like the normal GT 5-speed or the GT500 6-speed ( which can be retrofitted into a GT).
TREMEC MAGNUM XL
Too bad you are not closer as I want to go the other way from manual to auto this winter.
TREMEC MAGNUM XL
Oh I cee, hows the stock manual transmission, hard to shift at normal driving and maybe at wot as well? Becase there a totalled mustang that sells the trans,harnes,clutch,pedal assembly,pcm,harnes,flexplate,shifter for 1000$ but Im not sure I will like that transmission and maybe keeping the 1000 and save it up for a magnum
CiniZter
25
4/28/16 05:41 PM
