Transmission swap?automatic to manual
Old Sep 12, 2012 | 11:48 PM
Victorfriessen's Avatar
Would anybody recommend me to change the automatic trans for a manual one? Does the manual on a 08 S197 have common issue like problems with shifting and stuff like this?
Is there any 6speed that is offered to work with the Mustang gt 2008?
Old Sep 13, 2012 | 07:26 AM
Doogie's Avatar
I would check out this new Tremec 6-speed as it eliminates all the shifting issues associated with the externally mounted shifters like the normal GT 5-speed or the GT500 6-speed ( which can be retrofitted into a GT).
TREMEC MAGNUM XL
Too bad you are not closer as I want to go the other way from manual to auto this winter.
Old Sep 14, 2012 | 11:26 PM
Do you have the new tremec or the t-5?
Old Sep 16, 2012 | 03:13 PM
Doogie's Avatar
Neither as I am still running the stock 3650 5-speed
Old Sep 16, 2012 | 10:28 PM
Oh I cee, hows the stock manual transmission, hard to shift at normal driving and maybe at wot as well? Becase there a totalled mustang that sells the trans,harnes,clutch,pedal assembly,pcm,harnes,flexplate,shifter for 1000$ but Im not sure I will like that transmission and maybe keeping the 1000 and save it up for a magnum
Old Sep 17, 2012 | 06:18 PM
BradGT's Avatar
Save for the magnum, this trans is a piece of crap, mine went out at 40,000, but thousand is not bad for everything cause I don't know what you need with the magnum,
Old Sep 17, 2012 | 10:34 PM
I guess magnum it is,wich aftermarket transmission would you go with for a automatic?
Old Sep 19, 2012 | 07:39 AM
BradGT's Avatar
4r70w or a C4 haha
CiniZter
25
Apr 28, 2016 05:41 PM
yabutt
Oct 23, 2015 01:05 PM
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
Ray11
Sep 25, 2015 12:43 PM
