TPS Issue?
Old Feb 20, 2014 | 09:48 AM
Matthew Warner's Avatar
TPS Issue?
Total Newb here.. I have an issue that I think may be my TPS but I'm not sure if this is where to ask, so i guess i will.
I have a 2005 Mustang GT
My idle speed is all over the place, downshifting after depressing the clutch my RPM's climb. At idle with the clutch depressed my rpm's climb then dive.. After about 10 minutes of driving the car goes into failsafe mode and I get the check engine light.
I am running the 62mm BBK throttle body the BBK CAI. I have cleaned the throttle body until it shines...... I am not running a custom tune.
Do you think it's my TPS? If I change my TPS sensor should I also change the TPS motor?
Once again nice to be with like minded nuts... Thanks for any and all info.
Old Feb 24, 2014 | 08:34 AM
05YellowGT's Avatar
It's probably your tune, the BBK is larger than stock and should require a tune.
Old Feb 27, 2014 | 10:17 AM
bullsguy's Avatar
Check your TPS voltage, probably needs to be adjusted.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
