Time for new rotors? Shaking...excuse for mods
Old Oct 14, 2008 | 07:24 PM
azoufan's Avatar
I have developed a steering wheel shake at nearly all speeds over 10MPH now, not present at any time before. I've had the springs, struts, shocks, rims and tires for tens of thousands of miles now, so I'm quite sure it's not related to that. The car has 58K miles on it now, still on stock rotors and pads. Is this steering wheel shake a symptom of warped rotors? I'm thinking so from what I've read, but I'm looking for confirmation on that before I dump several hundred dollars into new rotors and pads.
But...if I'm going down that road, might as well do SS brake lines too right? So assuming that's the case, any recommendations on rotors, pads and brake lines as well?
Old Oct 15, 2008 | 10:57 AM
Derek@DRI's Avatar
Well if its just vibrating when driving than it is not your rotors. If it was your rotors the steering wheel would only vibrate when braking. It could be your tires are out of balance, depending on the weights you have if you have sticky weights they might have come off. Could be other things such as a Driveshaft, bad bushings, etc.
Now if you want to upgrade your brakes anyways, we have packages put together. Our packages were designed with cost and performance in mind. They are the most popular and economic Rotors, Pads, and Lines. Now we can go with cheaper rotors, or more expensive its up to you. Take a look at them and let me know if you have any questions or what you think, I can also mix and match with any other brands you might like/want.
http://dagostinoracing.com/index.php...8_1_1200_17763
Derek
Old Oct 15, 2008 | 05:40 PM
classix_stang289's Avatar
if your tires are not out of balance then did you check for damages to the tires? Hitting potholes often?
sometimes a tire can get damaged and shift a belt in them
Old Oct 16, 2008 | 11:38 AM
azoufan's Avatar
Thanks for the replies. I'll take the car to the tire shop this weekend to get it checked out. Yes I would normally do at least initial troubleshooting myself but I had shoulder surgery and can't lay down on the ground. I feel like such a metro-sexual "I drive a used BMW and have no idea if it has 4, 6 or 8 cylinders, nor what a cylinder is, is my hair ok" lamo for that. I better wear my sling when I pull into the tire shop or they are going to make fun of me while I'm in the waiting room.
Old Oct 16, 2008 | 05:44 PM
don_w's Avatar
Originally Posted by azoufan
... any recommendations on rotors...
Well, the rear rotors on the GT are the same as on a rental V6 Mustang, and are a direct swap. Don't ask me how I know this...
Old Oct 16, 2008 | 09:37 PM
Stoenr's Avatar
At those speeds, Id look into a tire issue also. Awaiting shops findings.
Old Oct 17, 2008 | 08:04 AM
Derek@DRI's Avatar
Old Oct 18, 2008 | 02:21 PM
scramblr's Avatar
LOL...Don you're out of control!!!
Old Oct 18, 2008 | 03:01 PM
70MACH1OWNER's Avatar
DONnnnnnn..... Do they come drlled and slotted?
Old Oct 18, 2008 | 06:27 PM
travelers's Avatar
I would also have them look at the alignment.
Old Oct 18, 2008 | 07:09 PM
afcop13's Avatar
LOL.........now I'll have to call Hertz to see how much a 2-4 hr rental will be.
Old Oct 19, 2008 | 11:33 AM
azoufan's Avatar
Had the tires checked out yesterday, the drivers side front was off 2 ounces and the passenger side front was off 4 ounces. It drives like a new car now. Now, how to I justify new rotors...
Old Oct 19, 2008 | 01:08 PM
scramblr's Avatar
Don't ask Derek how to justify it...He has a very long list to help you out.
Old Oct 20, 2008 | 03:23 PM
Derek@DRI's Avatar
Haha well i'm happy you got it resolved. As for rotors, well you just might as well upgrade them you have upgraded everything else.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
tdf017
Aug 5, 2015 10:13 AM
mrrooney
Jul 26, 2015 09:35 AM
