Synthetic manual tranny fluid!
I would like to go with a synthetic tranny fluid, I did do a search and did not find much. One guy said he did some research and even called Mobil and that they said it was a NO for the ford tranny, then I read a thread where a member went with Mobil 1 full synthetic ( mercon compadible) ATF.
OK, so I am confused now
, anybody got some constructive input to this thread????????????
Originally posted by MJC302@November 22, 2005, 9:16 PM
David, that was me that called Mobil about the Synthetic trans fluid. BUT the topic was about an automatic tranny. We autos may only use MERCON V ATF. The synthetic Mobil 1 ATF is good for MERCON rating that meets the spec for the manual trans.
Originally posted by davids2toys@November 27, 2005, 6:38 PM
For all the same reasons people put syn in the crankcase...I put the Mobil 1 in the tranny last nite
Is there an advantage to running full synthetic in the tranny? I mean, I realize it'd probably last longer, lubricate better, etc., but does it make it quieter or increase power a bit?
It may make it a little louder. But it will run cooler use less power and last longer. It has been my experience that some times it makes it harder to shift at high rpms. I believe this is because synchronizers are also lubracated better so it takes more pressure on the shifter and takes more time for the gears to mesh.
