Synthetic manual tranny fluid!
Old Nov 22, 2005 | 04:55 PM
davids2toys's Avatar
I would like to go with a synthetic tranny fluid, I did do a search and did not find much. One guy said he did some research and even called Mobil and that they said it was a NO for the ford tranny, then I read a thread where a member went with Mobil 1 full synthetic ( mercon compadible) ATF.
OK, so I am confused now , anybody got some constructive input to this thread????????????
Old Nov 22, 2005 | 05:42 PM
PONY XPRESS's Avatar
Hit the "NEO" oil web site. They use to sell a 7wt (which I still have & use) They may have a new name for it. Worked great in my GT-1 SCCA car & circle track car. 650HP+
Old Nov 22, 2005 | 05:46 PM
Firedude's Avatar
Been using Royal Purple synthetic ATF for 6000 plus miles without any problems. Can't see how it would be anything but good.
Old Nov 22, 2005 | 06:15 PM
Indystang's Avatar
I am interested in this also. I switched my 89 GT over to all Synthetic and man what a difference! Keep us posted what you find out. Thanks
Old Nov 22, 2005 | 07:11 PM
killo-11's Avatar
x2 on the Royal Purple synthetic ATF but I added 1 bottle of ford friction modifier for positrac rear ends. Shifts like glass at all engine rpm, 3500+ miles on the oil change.
Old Nov 22, 2005 | 08:13 PM
MJC302's Avatar
David, that was me that called Mobil about the Synthetic trans fluid. BUT the topic was about an automatic tranny. We autos may only use MERCON V ATF. The synthetic Mobil 1 ATF is good for MERCON rating that meets the spec for the manual trans.
Old Nov 23, 2005 | 06:37 PM
Cool, thanks for clarifying
Old Nov 25, 2005 | 09:03 PM
Mongoose's Avatar
Why do you want to do this?
Old Nov 27, 2005 | 06:35 PM
For all the same reasons people put syn in the crankcase...I put the Mobil 1 in the tranny last nite
Old Nov 28, 2005 | 10:04 AM
The Lyin' King's Avatar
Mobil 1 Full Synthetic ATF is Mercon compatible. I've been running it for the last 13k miles in my manual tranny with no problems.
Old Nov 28, 2005 | 11:24 AM
y22kc's Avatar
Is there an advantage to running full synthetic in the tranny? I mean, I realize it'd probably last longer, lubricate better, etc., but does it make it quieter or increase power a bit?
Old Nov 28, 2005 | 12:49 PM
killo-11's Avatar
It may make it a little louder. But it will run cooler use less power and last longer. It has been my experience that some times it makes it harder to shift at high rpms. I believe this is because synchronizers are also lubracated better so it takes more pressure on the shifter and takes more time for the gears to mesh.
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
BigHoss
Sep 21, 2015 10:03 AM
jim010
Sep 14, 2015 10:15 PM
