strange sound any help
Old Oct 19, 2013 | 02:42 PM
agomez's Avatar
Old Oct 19, 2013 | 06:02 PM
wow that is strange. Is the power steering fluid up to the right level?
Old Oct 19, 2013 | 06:29 PM
agomez's Avatar
Yes I checked the level and its good and alternator was rebuilt so I don't know what could it be I don't think its the belt
Old Oct 19, 2013 | 06:45 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Turning change the noise? My guesses by just listening to the video are 1.) One of those idler pullies are shot. Or 2.) Timing chain tensioner plastic is wore out and your getting chain to metal slide contact. Hard to tell when your not there
Old Oct 19, 2013 | 06:57 PM
agomez's Avatar
As I'm drving it sounds louder but only from 1500 to 2500 rpm every gear I don't know if the gunk cleaner affected it or water but how can you tell of the belt is worn
Old Oct 19, 2013 | 07:04 PM
Bear Eats King...
Bear ****s Bone
Thats not a belt noise though...
Old Oct 19, 2013 | 07:08 PM
agomez's Avatar
Wheres the timing chain tensioner plastic cause also their is no leak from the power steering
Old Oct 19, 2013 | 07:16 PM
pebkac's Avatar
http://www.agcoauto.com/content/news/p2_articleid/115
Old Oct 19, 2013 | 09:59 PM
agomez's Avatar
Thanks that is some good info ill look at that
Old Oct 23, 2013 | 11:29 AM
Imatk's Avatar
Might be a bad bearing on one of your pullies. If you have a stethoscope (mechanics not medical) you could pinpoint which one is causing the noise if it IS a pulley.
I had one go on my car but it never sounded that bad.
Old Oct 29, 2013 | 12:10 AM
agomez's Avatar
Which pulley was it
Old Oct 29, 2013 | 10:58 AM
Imatk's Avatar
One of the belt pulleys below my blower.
Old Oct 31, 2013 | 06:21 PM
agomez's Avatar
I think its gonna be one of my idler pulleys
Old Oct 31, 2013 | 07:30 PM
pebkac's Avatar
timing tensioner or idler pulley. To find out simply take the serpentine belt off and if it still makes the noise it is likely the timing tensioner. If it goes away turn it off and while it is off You may just be able to tell which it is just by spinning it by hand, maybe even before starting it... If it goes away with the belt off I would simply replace all the pulleys they are not expensive.. My bet is the timing tensioner. That just sounds so much like the links dragging on the timing cover.... Good luck for the other however.
Rando
Aug 25, 2021 11:12 AM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
