strange sound any help
wow that is strange. Is the power steering fluid up to the right level?
Originally Posted by Glenn
(Post 6703015)
Turning change the noise? My guesses by just listening to the video are 1.) One of those idler pullies are shot. Or 2.) Timing chain tensioner plastic is wore out and your getting chain to metal slide contact. Hard to tell when your not there
Originally Posted by texastboneking
(Post 6703031)
Originally Posted by agomez
(Post 6703039)
As I'm drving it sounds louder but only from 1500 to 2500 rpm every gear I don't know if the gunk cleaner affected it or water but how can you tell of the belt is worn |
(Post 6703031)
(Post 6703043)
Wheres the timing chain tensioner plastic cause also their is no leak from the power steering
Might be a bad bearing on one of your pullies. If you have a stethoscope (mechanics not medical) you could pinpoint which one is causing the noise if it IS a pulley.
I had one go on my car but it never sounded that bad. |
Originally Posted by Imatk
(Post 6704680)
One of the belt pulleys below my blower.
(Post 6707350)
timing tensioner or idler pulley. To find out simply take the serpentine belt off and if it still makes the noise it is likely the timing tensioner. If it goes away turn it off and while it is off You may just be able to tell which it is just by spinning it by hand, maybe even before starting it... If it goes away with the belt off I would simply replace all the pulleys they are not expensive.. My bet is the timing tensioner. That just sounds so much like the links dragging on the timing cover.... Good luck for the other however.
