Stock Swaybars
Old Jul 14, 2008 | 04:40 PM
08Bullitt0621's Avatar
Stock Swaybars
Are the stock sway bars really all that bad or is the give/roll mostly due to the softer rubber bushings?
Old Jul 14, 2008 | 04:58 PM
Imatk's Avatar
The rear one is fine... the front one is kind of spindly compared to say the FRPP part.
I put the FRPP sways on my car and noticed a significant difference.
Old Jul 14, 2008 | 05:22 PM
08VistablueGT's Avatar
I don't know about that. I upgrade my stockers to Eibachs and the rear is signifcantly thicker than the OEM one. I did install billet end links as well.
Old Jul 14, 2008 | 05:46 PM
travelers's Avatar
I put the BMR front and rear that are adjustable. the bushing are prothane
Old Jul 14, 2008 | 08:07 PM
aircare84's Avatar
The stock GT front bar is actually quite decent. The rear can be improved on with a heavier/larger bar & better links.
Have the Eibach front/rear ones on mine. Noticed an improvement when I installed the rear, not much difference when I added the front. Stretched the project over 2 weekends.
Old Jul 15, 2008 | 08:05 AM
DarkFireGT's Avatar
The stock front one can't be all that great, because I deleted mine and really don't feel much difference on the street, at least. I'm sure aftermarket bars with stiffer bushings would be a good improvement.
Old Jul 15, 2008 | 08:48 AM
06GT4RAD's Avatar
I have upgraded to the Steeda front and rear bars with the billet end links for the rear and the billet caps up front and they made a pretty significant change in the car.
Worthwhile upgrade in my opinion. The car has almost no body roll at all now.
Old Jul 15, 2008 | 09:06 PM
Thanks all. I don't think I'll mess with the stock swaybars. I've got Steeda sports, tokico D-specs, BMR brace and adj panhard sitting in my garage. I want to get rid of the 4x4 look and improve handling a bit. Do I need to be concered with bumpsteer and pinion angles, etc with a 1" drop?
Old Jul 16, 2008 | 02:49 PM
Pwny's Avatar
I replaced my stock swaybar with a BMR piece. Definitely thicker and made a difference.
Old Jul 16, 2008 | 06:28 PM
How do you like the D-specs? Can you adjust ride height as well?
Old Jul 16, 2008 | 08:27 PM
There not installed yet just sitting in my garage. You can't really adjust the ride height with the D-specs just the handling.
Old Jul 16, 2008 | 08:58 PM
06GT4RAD's Avatar
To adjust ride height you will need a coil over setup.
The New Eibach setup looks very nice.
09-gt/cs
Oct 15, 2015 10:03 AM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Ray11
Sep 25, 2015 12:43 PM
samjluck
Sep 17, 2015 10:24 PM
