still have traction problems
Old Apr 19, 2006 | 10:57 PM
tkogt's Avatar
<div class='quotetop'>QUOTE(kampendmk @ April 19, 2006, 11:42 PM) Quoted post</div><div class='quotemain'>
I`m 57 i can drive as good as you guy`s and better, hitting a brick wall because the body was tiwisting the 3rd gear wouldn`t go in the hurst it was no porblem i`m drunk to can`t spell
[/b][/quote]
he was reaching into the back seat for a beer ( the body was tiwisting? )
and its hard to shift with your left hand, when your steering with your left knee.............. [img]style_emoticons/<#EMO_DIR#>/04.gif[/img]
thing that make you go...hhhhhhmmmmmm
jay
Old Apr 20, 2006 | 06:50 AM
rony1976's Avatar
That's what I understand from this "... in the hurst it was no porblem i`m drunk to can`t spell..." [img]style_emoticons/<#EMO_DIR#>/lol.gif[/img] [img]style_emoticons/<#EMO_DIR#>/rofl2.gif[/img]
Old Apr 20, 2006 | 10:15 AM
Burke0011's Avatar
Big Falken Tires
Geez.... take the extra five minutes and type a coherent post......
Old Apr 20, 2006 | 10:29 AM
rony1976's Avatar
EVERY POST I SEE FROM THIS GUY is a grammar dissaster..
Old May 14, 2006 | 12:03 AM
kampendmk's Avatar
Learn how to drive 1.826 60ft times last time out street tires and gears
Old May 14, 2006 | 12:08 AM
kampendmk's Avatar
learned how to drive ran 1.826 60ft times with stock gears and tires
Old May 14, 2006 | 06:43 AM
mikem's Avatar
Originally Posted by 94tbird
i still cant hook up that well. im going sideways when i launch. i think this is killing my quarter mile times as i cant break a 13.8 with the mods i have below. i see others with less mods running 13.5 or 13.2 and such. What can i do to get traction. Will the LCA's solve this?
I shouldnt be helping you but=First, If you are driving thru the water box you are driving to the line with wet front tires.Dont Drive thru the water.Go around and back into with just rears.Why the hell would you run 20psi in all four wheels.Is your car all wheel drive?You should run 50psi in the front and 25 in the rear with stock tires.Drag radials between 12 and 15.Launch car between 2000 and 2500 and you should be shifting at 6200RPM.Install a ratchet strap arround drivers motor mount and Kframe.Tighten till motor pulls down a little.You wont have shifter problems anymore.
Old May 14, 2006 | 07:30 AM
94tbird's Avatar
well i havent been going through the water period. in fact i was barely doing a burnout at all. last week i started doing the burnouts and it helped my 60' times from averaging a 2.1-2.2 to a solid 2.0 consistently and i got a 13.6 in the 1/4. i was told that with street tires we cant use the water box period. it was only for slicks and drag tires
Old May 14, 2006 | 11:20 PM
300HPGT's Avatar
like mikem said make sure your front tires have lots of air for less rolling resistance. When pumped up like that less rubber meets the road causing less friction. Rear tires @ 25 psi. launch @ 2000. If the car still bogs raise the RPM's just a bit. I have bested a 13.4 @ 106 w/ a 2.0 60' time on street tires. But my 20's arent very forgiving with the low profile tires. There is no sidewall flex for a good launch. and Practice makes perfect!!!!!
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Sep 8, 2015 10:45 AM
