still have traction problems
Old Apr 12, 2006 | 09:15 PM
94tbird's Avatar
i still cant hook up that well. im going sideways when i launch. i think this is killing my quarter mile times as i cant break a 13.8 with the mods i have below. i see others with less mods running 13.5 or 13.2 and such. What can i do to get traction. Will the LCA's solve this?
Old Apr 12, 2006 | 09:23 PM
kampendmk's Avatar
yes i have bmr lca arm`s before 60 ft 20,11 now 19.56 with lca`s stock gears and tire`s no wheel hop at all. best time so far 1/8 8.656 80.96
Old Apr 12, 2006 | 10:29 PM
stang9325's Avatar
what rpm's are you launching at? I launch around 2000-2500 and have similar mods to you and run a 13.2 (as you mentioned). Just try and adjust your launching technique. Feather the clutch a bit and this should help you. Did you lower the pressure in your rear tires?
Old Apr 12, 2006 | 10:38 PM
kampendmk's Avatar
learn how to drive would help
Old Apr 13, 2006 | 07:03 AM
94tbird's Avatar
<div class='quotetop'>QUOTE(kampendmk @ April 12, 2006, 11:26 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
<div class='quotetop'>QUOTE(kampendmk @ April 13, 2006, 12:41 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
and you can learn how to not repeat yourself. i dont need your comments anymore thank you. try moving your username to stangnet. they would love to have you
[/b][/quote]
I am trying to launch at 2000rpms. i tried about 20psi in all 4 tires for one run and got even worse times than the 30psi or so i had in them before.
Old Apr 13, 2006 | 07:40 AM
BMR Fabrication Inc.'s Avatar
You're definately going to benefit by replacing your control arms. I would recommend doing the upper and lowers at the same time and you shouldn't have a problem hooking anymore. Let me know if I can help you with anything else.
Jason/BMR
Old Apr 13, 2006 | 01:23 PM
firestang70's Avatar
<div class='quotetop'>QUOTE(94tbird @ April 13, 2006, 8:06 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
94 try keeping your rear tires 20-15 psi, fill the fronts to 40 psi. Also has all of your 60 ft times been consistent. The hydraulic clutch on these can be a little goofy. You may want to also try a UCA with the LCAs. If you drive mostly on the road, get the poly ends(they are less noisy). Hope this helps.
Old Apr 13, 2006 | 01:55 PM
Cleveland's Avatar
Dont flame me here but I believe you need more practice driving and launching the car with that box.
-Dan
Old Apr 13, 2006 | 03:16 PM
ZGarske01's Avatar
learning to drive is the best thing you can do for a car... i have alot of suspension goodies and i "can" still have traction problems if i want its all a matter of learning to drive your car as best as possible while still getting traction
Old Apr 14, 2006 | 11:00 AM
don_w's Avatar
Ron, two words: "Drag Tires"
Old Apr 14, 2006 | 02:28 PM
dustindu4's Avatar
9 is not my lucky number.
[/b][/quote]
this coming from a guy who was asking people how to shift a few months ago
[img]style_emoticons/<#EMO_DIR#>/lol.gif[/img]
Old Apr 14, 2006 | 02:48 PM
Mongoose's Avatar
<div class='quotetop'>QUOTE(BMR Fabrication Inc. @ April 13, 2006, 8:43 AM) Quoted post</div><div class='quotemain'>
Jason/BMR
[/b][/quote]
I have BMR loweres and am happy with them. There is just too much noise with the upper arm and it is a pain to install so I did not. Purchase the non adjustable lowers with POLY bushings. If you plan to lower car too save on shipping and purchase panhard at the same time.
Old Apr 14, 2006 | 03:03 PM
Dubai's Avatar
<div class='quotetop'>QUOTE(don_w @ April 14, 2006, 11:03 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
ya dan is right drag tires and LCA [img]style_emoticons/<#EMO_DIR#>/drool.gif[/img]
Old Apr 15, 2006 | 06:52 AM
HiRoller's Avatar
<div class='quotetop'>QUOTE(dustindu4 @ April 14, 2006, 4:31 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Dude you're right.....I thought I recognized that user name......... [img]style_emoticons/<#EMO_DIR#>/icon_rolleyes.gif[/img]
Old Apr 16, 2006 | 11:53 PM
kampendmk's Avatar
I did a 1.948 and 1.951 60ft last week at irwindale 1000 rpms flooring it after it took off ,street tires and gears, start like your street racing from light and don`t want get the cops attenion spinning tires it works great . How many times have seen dragracer run four seconds in rail smoking tires.
Old Apr 17, 2006 | 08:10 AM
rony1976's Avatar
Hey Dennis, are you still having trouble with this?
"I got a sctx2 tune installed at racer edge downey cal went to irwindale drag strip .best time stock 9.215 ran five times everytime i ran the car had so much torque 312tq it would spin the tires everytime i try to shift to 3rd it was like hitting brick wall it would not go in what ever i tryed Do i need a shifer kit i aleady have saleen short shifter"
This is from your "help can`t hit third gear, A brick wall" thread, just wondering if you are still hitting a brick wall, or if you are having so much torque, or if you learned how to drive AND WRITE yet...
Old Apr 17, 2006 | 08:48 AM
94tbird's Avatar
hahahahaha oh man "lol"
Old Apr 17, 2006 | 08:56 AM
rony1976's Avatar
he he he, I figured if he had the ballz to tease you about learning how to drive, he should have enough ballz to take the flaming for not knowing how to drive AND write! he he he
[img]style_emoticons/<#EMO_DIR#>/flamethrower.gif[/img]
Old Apr 19, 2006 | 10:39 PM
kampendmk's Avatar
I`m 57 i can drive as good as you guy`s and better, hitting a brick wall because the body was tiwisting the 3rd gear wouldn`t go in the hurst it was no porblem i`m drunk to can`t spell
Old Apr 19, 2006 | 10:41 PM
94tbird's Avatar
so what you are saying is your a drunk old guy who cant spell, type, write, or drive? [img]style_emoticons/<#EMO_DIR#>/biggrinjester.gif[/img]
