steeda stock shifter bushings
Old Aug 3, 2005 | 09:00 PM
onebadgsx's Avatar
this was a great mod for 25 bucks. makes the factory shifter alot more ridged. i like the factory throw, but was looking for something a little more stiff and that what this bushings do.
Old Aug 3, 2005 | 09:02 PM
TURBO 05's Avatar
does it make it noisier?
Old Aug 3, 2005 | 09:11 PM
onebadgsx's Avatar
not a big difference noise. it is louder but you have to have the radio off to really tell. you deffinately feel the shifter click into gear now. more like a upgraded shifter. not as noisey as a tri-ax or b&m.
Old Aug 4, 2005 | 10:37 AM
Kluski's Avatar
I did it to mine too. I liked it. It was easy too.
Old Aug 4, 2005 | 10:44 AM
Satin Silver 05's Avatar
Where did you get them? Did you install them yourselves? If so was it easy?
Old Aug 4, 2005 | 10:57 AM
Kluski's Avatar
Bought them from Steeda.
It took no time at all, and I did not remove the driveshaft, but I did remove the shifter.
Basically, there are two bolts and two nuts (from under the car) to remove from the shifter, and it comes off the car. Two bolts up front, and two nuts in the back. After you remove the nuts/bolts, let the shifter fall down. You can then reach the bushings.
I forgot the sizes, but I know I needed a wrench to reach the front bolt. A socket was too big.
Old Aug 4, 2005 | 04:52 PM
onebadgsx's Avatar
you need a 10mm deep socket for the back two nuts, the front bolt is a 10mm wrench, real easy you dont have to remove the driveshaft. let the shifter fall down, pull the bushings out of the front swap in new ones along with the factory metal inserts, and for the back remove the factory bushing and start the new steeda one and tap it on the rest of the way with a hammer. mount the shifter.
Old Aug 4, 2005 | 08:02 PM
Thanks for the info. one more question, did you do it on jackstands or on a lift? I dont have access to a lift. sounds like a very worthwhile mod.
Old Aug 4, 2005 | 09:46 PM
onebadgsx's Avatar
i just jacked up the pass. front a good amount and put a jack stand under that one side and completed the job that way. 20 mins tops if you go under will all your tools.
Old Aug 6, 2005 | 05:12 PM
Kluski's Avatar
I used jack stands also.
Old Aug 7, 2005 | 07:37 PM
Cool! thanks for the info.
Just ordered mine, was theis the part # 555-7095, Urethane Bushings for O.E. Shifter?
Old Aug 8, 2005 | 12:27 PM
onebadgsx's Avatar
sounds right
Old Aug 8, 2005 | 06:22 PM
GRAYPNY's Avatar
Stupid question, do you have to remove the shifter **** to let it drop down?
Old Aug 8, 2005 | 08:25 PM
onebadgsx's Avatar
yep just lift the boot up then twist off the ****.
Old Aug 9, 2005 | 10:49 AM
Kluski's Avatar
It helps since it lets a lot of light in with the boot off.
SilverBullet13
Aug 13, 2015 09:11 AM
ustabawannab
Aug 5, 2015 08:32 PM
Jul 30, 2015 06:47 AM
