Steeda cold air intake questions
Old Jul 26, 2011 | 02:30 AM
metroplex's Avatar
I'm looking at buying the 555-3120 kit (no elbow kit) and wanted to know if it was a 90mm housing. It seems if I install just this cold air kit with the stock rubber elbow, I'd get the same setup as the Shelby GT - is this correct?
I also have the SCT Pro Racer Package. I could opt for an aftermarket tune, or even the canned Steeda tune, but I already have the SCT Pro Racer Package and just need the transfer function for the Steeda cold air kit. Does anyone know if the value file provided in the pro racer package is the correct one, or happen to have a Shelby GT with the Pro Racer Package and can share their transfer function?
Is the Steeda unit a high quality kit?
Old Jul 26, 2011 | 07:52 AM
SteedaGus's Avatar
The 555-3120 is the same kit used in the 07-08 Shelby GT's, so if that is what you are looking for that is exactly what you need.
There should be a value file in the Pro Racer package for the intake which will be the 90mm file. That file will get you super close and you can find tune from there.
If its not in there I would be glad to send you that value file.
Old Jul 27, 2011 | 07:04 AM
mustangtim01's Avatar
I have the Steeda kit and I could not be happier with it. I have seen great gains with the kit. It is a great quality piece and I have had no issues with it.
I made a couple calls to Steeda before ordering it and they were very helpful in regards to customer service. You not only get the kit, but you get a helpful team behind you!
It is a must buy!!
Old Aug 2, 2011 | 05:35 AM
metroplex's Avatar
I installed my Steeda kit last weekend and have been using it. I noticed that the weatherstriping seal is pushing into my hood insulation just a tad in a few spots. The heat shield is about 1-2mm away from the ABS HCU electronic module but I can't seem to make it contact, so it should be ok?
It was difficult to slip the stock air hose over the 90mm MAF housing, but some WD40 helped out, sort of like swapping grips on my motorcycle.
Below 3000 RPM, nothing feels different. Above 3000 RPM, the engine comes alive. Even with the stock mufflers, the car always sounded aggressive outside. Now above 3000 RPM, it sounds alive.
I haven't tried driving it through the rain yet, it would be interesting to see what happens with heavy rain and flooded roads.
I didn't like how the plastic velocity stack doesn't have a gasket seal to the heat shield, so I used a tiny layer of RTV gasket for the outermost ring of the velocity stack and torqued the 4 housing bolts to about 7 ft-lb and used blue threadlocker.
Old Aug 3, 2011 | 07:54 AM
SteedaGus's Avatar
Installing the 3120 intake kit on the stock inlet hose does require a little pushing as it is a tight fit. The weatherstrip seal is meant to push and seal, all is good there.
There was no need to add extra sealer to the velocity stack. Ford flowbenched this intake and found no air seepage there and approved the design so there is nothing to worry about there.
Good to hear you like the increase in performance. Enjoy!
Old Aug 3, 2011 | 08:04 AM
metroplex's Avatar
Gus, thanks for the help. Steeda was the only manufacturer that really went the extra step to make sure I would be able to use the cold air intake with my SCT kit. Ford Racing basically told me to go pound sound or buy their tuner package.
I looked at Steeda's other products (control arms, sway bars, etc...) and would not hesitate going that route as the quality is noticeably better than the competition.
Old Aug 6, 2011 | 02:29 PM
Ronnie06LLGT's Avatar
I have the Steeda CAI w/high flow tube, UDP, rear Lower control arms, 3rd link, panhard bar and ultralite lowering springs. Car was dyno tuned with Predator tuner. I am extremely happy with the performance and handling gains with the Steeda products. Car also has BBK TB and Bassini high flow catted x-pipe and axle-backs and CDC shaker hood..
Old Aug 7, 2011 | 02:41 PM
mustangmike06's Avatar
What numbers did you put down with that set up?
Old Aug 8, 2011 | 05:46 AM
05YellowGT's Avatar
Here's a sheet from early 05 when I had their CAI , UDP's , CMDP's and axle back exahust ...
jonser
Ecoboost
Aug 30, 2015 11:47 AM
jlaval05
Aug 27, 2015 10:08 AM
GT/CS Guy
Aug 13, 2015 07:54 PM
Ecoboost
Jul 25, 2015 06:32 PM
