Stalling
Stalling
My 07 gt 5spd dies coasting after heavy acceleration or high speed cruising, idk what causes this, it happens randomly not all the time but when it does it happen a few times in a row
Have you cleaned the throttle body?? I see that so often causing unusual problems.
Plugs changed on that 07?
Any codes?
Have you unhooked the battery to reset the ECU?
Any codes?
Any codes?
Any codes?
No codes, and ya I've disconnected the battery
I'll clean the tb just to see if it helps
Originally Posted by mustangstig
Try cleaning. Throttle body, cheap and can't hurt, try injector cleaner too. You might find a dead or dying coil plug too. I had a different issue but ended up being a bad coil. Good luck
Originally Posted by BradGT
I give all that a look, it just starts right back up instantly, so makes be think its something to do with the computer or electronics
This is a known concern with the 3v's. The way the PCV hose is routed straight into the intake track before the TB makes the TB gum up. Starting in 2007' they put a value in the ECU for this, called "CIB slude Multiplier" CIB stands for Closed In Bore. Still, they gum up too.
I would clean your TB before you go any further. While you're doing it you can disconnect your battery and allow it to reset the PCM fully.
Thanks, Doug
This guy had some problems with fuel pump/fuel pressure and related sensors. Long thread but you might glean something out of it.
https://themustangsource.com/f637/2-...4/#post6431251
Antigini-GT/CS
10/5/15 09:43 AM
9/23/15 03:21 PM
