Stalling
Old Oct 29, 2012 | 04:54 PM
BradGT's Avatar
Stalling
My 07 gt 5spd dies coasting after heavy acceleration or high speed cruising, idk what causes this, it happens randomly not all the time but when it does it happen a few times in a row
Old Oct 29, 2012 | 07:50 PM
BradGT's Avatar
**** no one again
Old Oct 29, 2012 | 07:54 PM
Have you cleaned the throttle body?? I see that so often causing unusual problems.
Plugs changed on that 07?
Any codes?
Have you unhooked the battery to reset the ECU?
Old Oct 29, 2012 | 08:05 PM
BradGT's Avatar
Any codes?
I only have 50k, i plan on changing the plugs soon but doubt it would cause random stalling
No codes, and ya I've disconnected the battery
I'll clean the tb just to see if it helps
Old Oct 29, 2012 | 11:26 PM
mustangstig's Avatar
Try cleaning. Throttle body, cheap and can't hurt, try injector cleaner too. You might find a dead or dying coil plug too. I had a different issue but ended up being a bad coil. Good luck
Old Oct 30, 2012 | 08:42 AM
BradGT's Avatar
I give all that a look, it just starts right back up instantly, so makes be think its something to do with the computer or electronics
Old Oct 30, 2012 | 08:47 AM
muscledom's Avatar
Sounds like a job requiring a scanner, wiring diagrams, and a power probe. That's ****ty man. Hope you get it quickly resolved.
Old Oct 30, 2012 | 10:00 AM
Doug@C&L's Avatar
This is a known concern with the 3v's. The way the PCV hose is routed straight into the intake track before the TB makes the TB gum up. Starting in 2007' they put a value in the ECU for this, called "CIB slude Multiplier" CIB stands for Closed In Bore. Still, they gum up too.
I would clean your TB before you go any further. While you're doing it you can disconnect your battery and allow it to reset the PCM fully.
Thanks, Doug
Old Oct 30, 2012 | 10:01 AM
BradGT's Avatar
Been doing for a while, it could go a month or 2 without doing it, maybe it's tune related, does seem to happen around when I reset my battery
Old Oct 30, 2012 | 11:33 AM
This guy had some problems with fuel pump/fuel pressure and related sensors. Long thread but you might glean something out of it.
https://themustangsource.com/f637/2-...4/#post6431251
Uofmrampage
Aug 2, 2022 02:55 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 23, 2015 03:21 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
Mug-stang
Jul 31, 2015 10:25 PM
