Smoke at start up
Old May 14, 2011 | 05:06 AM
ford4v429's Avatar
legacy Tms Member
Originally Posted by sinisterbullitt
I've just had problems with seals going bad on royal purple. I like mobile and amsoil. Plus even if I ordered bulk royal purple for the shop 200+ gallons its 9.75 - 10.50 a quart...yes not much cheaper than a case. Whereas Mobil is 7-8 and gets good reviews all around.
I'd read quite a few opinions about synthetics in general causing seal weepage- didnt harm the seals, supposedly the oils just prone to seep anywhere- part of its better lubricating qualities is smaller molecules or some bs that can encourage seal seeping- especially if put in a older motor that was run in with conventional lube, and already has a polished seal surface...general opinions were if using synthetics to do so on newer engines, as putting in older engines often resulted in wet seals...who knows, oil type/brand arguements are old as time...
I run rp synchromax in my 5 speed- it actually fixed a balky second, and gotta vouch for it...but i'm chicken to go away from motorcraft 5w20 semi... always heard of excellent engine life in the 4.6, so just no real justification for me...I do think a 'frantz' oil filter(and no more oil changes) sounds like a pretty proven system- especially in older cars with conventional clearances/oils...still a little iffy on the extremely tight fitted 4.6 and its water thin oil...staying with recommended here for now
Old May 14, 2011 | 11:03 AM
Bullitt995's Avatar
Originally Posted by Gtpony325
The only way that i know of to find out would be to start tearing into your motor
leakdown test
Mpaps
Oct 11, 2017 08:06 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
JonathonK
Sep 19, 2015 03:19 AM
