SLP's lose performance?
by changing to an SLP it does remove all friction/ back pressure for the engine. it may lower it slightly, but not by much. If back pressure were that big deal there would be alot less mustang owners with SLP. our kind isnt too keen on losing power. if we were we would all be driving 4 bangers
A motor with no resistance has nothing to work off of. A back pressure free exhaust would be like trying to walk without friction. Of course you can always go too far with the back pressure, which is what happens with imports when they put an exhaust that's too big on small cubic inch motors. There's a happy medium.
It has to do with the way air behaves at sub sonic speeds, super sonic aircraft (or well anything that can crack the sound barrier) can take advantage of an actual ram-air effect. At sub sonic speeds you cant ram air, the density remains the same, the only thing that effects the density of the air is temperature and humidity so with a "ram-air" vehicle your really taking advantage of cooler (denser) air, other than that, if the "ram-air" system can pass a greater volume of air (less restriction) than the original intake path, then you get power that way also (provided the original intake path poses some sort of restriction in the first place).
Ultimately "ram-air" is really just a very sexy cold-air set-up.
1 Post
Whatching some automotive program, they had one of the guys who designed the "ram air" concept on the 60's camero's he said it was worth 3hp max but it sure sold cars. Was actually an option on some. Yes it does look cool though.
I'll admit I'm ignorant as to what exactly back pressure has to do with torque, however I know that adding an intake and free flow exhaust can reduce it and on small displacement engines kills your low end (under 3000 rpm) torque. I also know that back pressure is important for keeping cylenders at optimum operating temperature. The purpose of the charge motion plates, atleast in Honda/Acura products, was to help with low end torque, they worked very similar to our 3v charge motion plates. They restrict the intake air under a predetermined rpm.
As I said before though, I really doubt removing the exhaust cans and adding straight pipes, as are slp lm's, is going to cause any real apriciable back pressure loss. You get plenty of back pressure from your cats and the exhaust manifold.
Just disconnect the battery and follow the directions in the owners manual to the letter...drive it spirited for 7 to 10 miles, and your problem will be solved!
Or, just drive it for a few hundred mile justr the way it is now , and it will self correct.
