Shimmy while braking with new rotors and pads
Old Sep 20, 2008 | 01:47 PM
Reelaction1's Avatar
I have searched the threads and haven't found anybody with the same issue so I thought I would try to find some help.
I just had new Powerslot rotors and Hawk ceramic pads put on my car and when it was taken for a test drive there was a shimmy in the front while braking. Normally this would indicate a warped rotor but I want to be sure there is nothing else that could be causing this. There was no shimmy with the OE rotors and pads.
Any advice would be greatly appreciated.
Old Sep 21, 2008 | 02:41 AM
jamesdem1123's Avatar
can you feel it from one side like left or right? if so try switching the rotor to the other side and make sure all your lug nuts are tight as well as the bolts for the caliper.
Old Sep 21, 2008 | 06:25 AM
mrv8outboard's Avatar
Also check for rust and debris under the rotor that could be causing a shim effect.
Old Sep 21, 2008 | 11:18 AM
drilled and or slotted rotors are not directional?
Old Sep 21, 2008 | 12:32 PM
tom281's Avatar
may sound stupid but are you sure your lugnuts are tight? crazy things happen.
Old Sep 22, 2008 | 05:02 PM
1fastbob's Avatar
If someone used an impact and hammered the hell out of the lugnuts this would cause warped rotors. The correct way to install lugnuts is by using a torque wrench.
Old Sep 23, 2008 | 09:25 PM
Stoenr's Avatar
Cant cross powerslots
Not stupid at all!
Agreed
Also, new rotors can be warped right out of the box, not all that uncommon.
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
