ROLL CONTROL/LINE LOCK
Old Feb 5, 2005 | 11:14 AM
Kahdir's Avatar
Thumbs up
Any installs yet?
Old Feb 5, 2005 | 11:40 AM
O5GT's Avatar
gonna take 2 kits to do it right...
Old Feb 5, 2005 | 03:56 PM
dhof303's Avatar
I wouldn't waste my money on this mod unless I was going to run slicks or drag radials. No need with street tires, heating them up more than rolling them over a few times is useless. $300.00 plus install seems like a lot to do a smooth looking burnout without the drivetrain/brake wear as with powerbraking in a stick car. If you are going to compete in a bracket class or a factory stock NMRA class then this is probably a good buy from PHP. B)
Old Feb 5, 2005 | 10:52 PM
Mongoose's Avatar
Originally posted by Blazing Saddles@February 5, 2005, 2:04 PM
Paul's High Performance sells a 2 solenoid kit.
http://secure-order-area.net/paulshp/cgi-b...d=9479655_15452
300 bucks. Now that is a hit. I will do it but will purchase parts elsewhere for a lot less. Notice the lines are not even prebent. Check out the photo on hotrod.com and you will see what I mean. I plan to use the overdrive switch with a relay for this line lock as its in the right location. Wheels will stay locked as long as you hold it in. Perfect !! I was going to use it to turn the nitrous on. OK I'll use it for both with a three way switch in the line.
ROLL ON
Old Feb 6, 2005 | 07:49 AM
Kahdir's Avatar
After seeing 2 Solenoids in the PHP kit, I'm not sure how the
Hurst kit
T-Handle will hold up...
BTW... Any comments/advice on slicks... Have an account w/ Mickey Thompson & Goodyear?
Old Feb 6, 2005 | 03:21 PM
Mongoose's Avatar
Hurst kit
I saw this Hurst kit also but it liiks like a plumbing nightmare where the Pauls deal was super easy. I would pay 200 if the steel tubings were prebent because they are a b---h amd I do not want to build the tools to do the small radia.
Old Feb 7, 2005 | 09:45 AM
Kahdir's Avatar
Thanks for your info.
Any prebent tubing kits out there? or is it better to outsource a shop to do it?
Fedupdave42169
Oct 20, 2015 10:29 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
Evil_Capri
Sep 25, 2015 12:56 PM
