Rear Diff Oil...How Much?
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
I am purchasing all the items I need for changing the gears to 4.10. I just need the oil. How much gear oil do I need to get to fill it to spec?
I am also changing the rear diff cover to the FRPP low profile cover. Does this increase the amount of fluid needed to fill it?
Thanks,
Sean
Thanks,
Sean
To the bottom edge of the fill hole (with the car level). if you put in a little too much it'll just come out the breather vent. Don't forget the friction modifier addititve if its a limited slip (Traction-Lok) diff. It shouldn't affect the amount of fluid needed by any substantial amount at all.
1 Post
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2006 Mustang Workshop Manual
SPECIFICATIONS
Lubricant Capacities
Additive Friction Modifier XL-3 118 ml (4 oz)
Approximate axle fill capacity 1.7 liters (3.15 pints) to the bottom of the fill hole with the axle at ride height
SPECIFICATIONS
Make sure you get ROYAL PURPLE 75w90 at WWW.AMERICANMUSCLE.COM. About $11.00 a bottle.PLUS FREE SHIPPING>
I use 75w140. If it only holds 3.15 pints, why get three bottles/6 pints/3 quarts? Even with a larger capacity diff cover, mine still held less than 2 (quart) bottles. I mean sure, you have some left over, but how often do you have to top off another quart in your diff?
Rando
8/25/21 11:12 AM
9/16/15 06:44 PM
