Rear Diff Oil...How Much?
Old Apr 21, 2008 | 06:42 AM
SeanD's Avatar
Question Rear Diff Oil...How Much?
I am purchasing all the items I need for changing the gears to 4.10. I just need the oil. How much gear oil do I need to get to fill it to spec?
I am also changing the rear diff cover to the FRPP low profile cover. Does this increase the amount of fluid needed to fill it?
Thanks,
Sean
Old Apr 21, 2008 | 07:16 PM
Cavero's Avatar
To the bottom edge of the fill hole (with the car level). if you put in a little too much it'll just come out the breather vent. Don't forget the friction modifier addititve if its a limited slip (Traction-Lok) diff. It shouldn't affect the amount of fluid needed by any substantial amount at all.
Old Apr 22, 2008 | 05:02 AM
SeanD's Avatar
That doesn't help me in purchasing the right amount. I need to know how many bottles to purchase.
Old Apr 22, 2008 | 05:14 AM
partsbill's Avatar
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2006 Mustang Workshop Manual
SPECIFICATIONS
Lubricant Capacities
Additive Friction Modifier XL-3 118 ml (4 oz)
Approximate axle fill capacity 1.7 liters (3.15 pints) to the bottom of the fill hole with the axle at ride height
Old Apr 22, 2008 | 06:11 AM
dustindu4's Avatar
9 is not my lucky number.
get 3 bottles
Old Apr 22, 2008 | 06:26 AM
RKNMACH's Avatar
Get three and you'll have some left over.
Old Apr 23, 2008 | 05:24 PM
2007REDFIREGT's Avatar
Make sure you get ROYAL PURPLE 75w90 at WWW.AMERICANMUSCLE.COM. About $11.00 a bottle.PLUS FREE SHIPPING>
Old Apr 23, 2008 | 06:04 PM
SeanD's Avatar
I thought it was 75W140 for the rear?
Old Apr 23, 2008 | 06:35 PM
Cavero's Avatar
That's what I'm running too
Old Apr 23, 2008 | 07:20 PM
karman's Avatar
That's what the owner's manual says...
Old Apr 23, 2008 | 07:26 PM
Hatchman's Avatar
I use 75w140. If it only holds 3.15 pints, why get three bottles/6 pints/3 quarts? Even with a larger capacity diff cover, mine still held less than 2 (quart) bottles. I mean sure, you have some left over, but how often do you have to top off another quart in your diff?
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Airborne42
Sep 24, 2015 10:27 AM
Sep 16, 2015 06:44 PM
